BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2000 ZX12R Barometer NEW TOPIC NEW POLL POST REPLY
maddfayce
SARR SGT@ARMS
posted June 21, 2009 01:24 PM
I am the proud owner of a 2000 ZX12R. I was told the FI light is on for the rear Barometer. What effect does this have on the performance of the bike if any?
shiphteey
posted June 21, 2009 05:14 PM
Your barometric pressure sensor should be bolted towards the upper right rear of your subframe. I would imagine if one was malfunctioning your ECU would be missing a fairly important parameter in calculating how much fuel to add at specific RPMS at specific throttle openings...among other things. Could be worth a couple ponies.
Gemini Motorcycles
2000redrocket
posted June 21, 2009 06:06 PM
actually it is needed for the speed density that your bike runs off of while driveing around not thrashing. it compairs the one in nthe tail to the one on the intake port to figure your altitude. i am not sure if there is a generic number it shoves in but it is important to run correctly. get one.
maddfayce
SARR SGT@ARMS
posted July 01, 2009 08:44 PM
Thanks for the info. They run about $99 in San Antonio.
squidbilly
super modified
posted July 02, 2009 05:22 PM
I was looking for one before and found out the map sensor is the same sensor they are interchangable. This might help you in you search for a used one.
maddfayce
SARR SGT@ARMS
posted July 02, 2009 11:14 PM
Thanks Billy. I would hate to get a new one when there is a used market out there.
EastBayDave
posted July 06, 2009 09:04 AM
check the cable for continuity first...
Enjoy the ride!
02' ZRX1200
00' ZX12R sold
maddfayce
SARR SGT@ARMS
posted July 06, 2009 06:27 PM
You mean breaks or frays?
zx12mark
posted August 03, 2009 01:53 PM
you got it
maddfayce
SARR SGT@ARMS
posted August 03, 2009 11:36 PM
Lines are good. Need a new rear tire before I get the sensor. Now when I do change it, I should wear gloves to install the new one?
0.23410105705261 seconds processing time
