BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Scotts Damper NEW TOPIC NEW POLL POST REPLY
vozizm
Got Nothing Witty To Say
posted October 04, 2002 12:54 PM
Scotts Damper
Anyone know the cheapest place i can get a Scotts Damper for my 02' 12-r....
Also anyone wanna talk about experince with this product?
Cowboy
posted October 04, 2002 01:02 PM
It is the only dampner i have ever owned so i can't do a comparison but it is incredible.
vozizm
posted October 04, 2002 01:09 PM
how hard was it to install....i know ya have to drill some holes...
ZHooligan
Post Whore Extraordinaire!
posted October 04, 2002 02:15 PM
Mark the location of the bracket, lift the tank up and pull the air cleaners. drill the two holes and use an air nozzle to blow any slag out of the snorkel(s). I find it helpful to stick duct tape in/below the area you are drilling to catch stuff as well. The hardest part ios lifting the tank! Then install the bracket with the two bolts provided. If you are a big guy with big forearms you may ask you wife or girl friend to start the two nuts as it is a tight fit. Then put the airfilters back in, drop the tank and reinstall the tanl cover etc. The Then remove the crown nut and install the new one provided with the kit. Install the dampner as directed and you are done. It is a 30 minute job only because you have to lift the tank.
It's easy and a kick ass dampner. Read the direction about adjustments. You have both a high and alow speed adjustment. Too much of one effects the other. They usually ship them pretty spot on for adjustment.
future; -- Youth is forever.
vozizm
posted October 04, 2002 03:32 PM
Muchas Gracias ZH!!!
Cowboy
posted October 04, 2002 04:15 PM
When reaching into the airbox i used the box end of a combination wrench with some black tape on the underside to hold the nut.Make triple sure you are drilling in the right spot.
ZHooligan
posted October 04, 2002 07:24 PM
Mount the damper on the tripple clamp to establ the spot to install the bracket that you drill the two holes for. It is easy. And cowboys tip on the wrench is agood one.
Phil
posted October 04, 2002 07:39 PM
I used a long needle nose vice grip to hold the nuts with the washers glued to em. Only problem with the damper was it started to leak fluid around an adjusting knob. A phone call to Scotts and it was fixed and returned within a week. Pretty good service I thought.
Dino
posted October 04, 2002 09:47 PM
And don't forget to put about a quart of vaseline on your forearm before entry
uh oh
ZHooligan
posted October 04, 2002 10:10 PM
If you don't use the vaseline, you might find your arm stuck and somebody sneaking up from behind you with vaseline!
ra12r
posted October 05, 2002 06:02 AM
You don't need to use the bolts if you "tap" the holes. I tapped mine 2 years ago, added some locktite,,,, NOOOOOO problems!!! There is an entire thread on that!!!!! Someone else posted the procedure.
Voz, there is a thread about every and anything usually to detail if you just take the time to look.
Rubber Pants
posted October 05, 2002 08:27 AM
According to Scott's, their damper will not fit the 02 as I phoned them........(i wanted one badly)something to do with the fact the tank is too close compared to previous model years. I opted for the Muzzy one : )
"Ya Gotta Have Big Ones!"
speeddemons.com
  Ignore this member    Click here to visit Rubber Pants's homepage.
beansbaxter
posted October 05, 2002 08:36 AM
Is there any steering dampener where you dont have to drill holes, but just bolts on??
kawachan
posted October 05, 2002 08:44 AM
MUZZY!!
RED NINJAS RULE!!
vozizm
posted October 05, 2002 04:00 PM
muzzy ...ungly ass hyper pro......and just about everybody else...
posted October 05, 2002 04:43 PM
Muzzy/hyperpro ugly??!! Don't tell my bike that! Looks great, works great, EASY to install!!!
vozizm
posted October 05, 2002 05:01 PM
not muzzy...but that hyper pro sure is...
RA12: Voz, there is a thread about every and anything usually to detail if you just take the time to look...
this is true...human nature to take the path of least resistance!
VOZ
0.22276782989502 seconds processing time
