BIKELAND > FORUMS > ZX12R ZONE.com > Thread: F-1 Car Clutch! NEW TOPIC NEW POLL POST REPLY
posted October 20, 2008 09:31 AM
F-1 Car Clutch!
Did anyone see the F-1 Clutch assembly out of an F-1 Car on Sunday? It was about the size of the clutch Pack in Peggy's 250 Ninja! it has to handle 850 to 900 HP and it tiny! The transmission is hooked directly to the engine and the clutch is directly to the transmission. The reason I mention this is the ZX12 clutch is smaller then the ZX14 but the 12 has at least twice as much clutch as the F-1 Car
posted October 20, 2008 10:07 AM
It probably had NOX's lock up clutch..........
NOX
PMRA / TMRC Super Street 4022
posted October 20, 2008 11:31 AM
SHHHHH............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
warbird
posted October 20, 2008 02:29 PM
I saw it Vincent...............my eye's bugged out.......... I just put a Rekluse Clutch,Basket and Plate's in a customers CRF 450 Friday, and it was much bigger than the F1 clutch. Truly amazing.
Did you hear them talking about accelerating and deaccelerating engine mass? ( rotating assembly ) From WAYYY up there in rpm's to total engine stop in 2/10ths of a second. No flywheel weight there huh?
That really was shocking.........the size ( or lack of ) that clutch basket............
I'd Rather Be Roadracing.
NOX
posted October 20, 2008 03:24 PM
Thats what is funny. It surprizes you............,
It does not surprize me.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 21, 2008 11:12 AM
Warbird, We all Know what is "possible" and what is not Possible and the Jewlers Watch size of that Clutch Basket was UN BELIEVABLE!! Yes I heard the 2/10th of a second and talk about QUICK Revs (Either way)! I have never cared that much for the F-1 Cars because everything is soo Secret! now that I have seen this, I have a LOT Better appreciation for what MONEY can buy you!
NOX, the ENTIRE Assembly could be HIDDEN between your 2 hands! I never knew what they were using but trust me it was never this!
flite leader
posted October 21, 2008 11:52 AM
save for starting & pitting the clutch has very little to do with the electronic upshifting
blipping achieved by the ecu. nascar went to a 2 plate clutch which reduced rotational inertia. the biggest advantage was it eliminated to a great degree the pressure against the flywheel. which on tracks where they did have a lot of shifting ot pit stops, was banging the
hell out of the crank thrusting it foward, causing low end reliabilty problems.
bend your mind.....
or break your ass...!!
posted October 21, 2008 01:38 PM
That is right about the Shifting! That is also why they throw away the clutch (on the start) and let everything else do the work!
flite leader
posted October 21, 2008 02:14 PM
i was down to road atlanta for the american le mans series, some of the ferrari gt2's were having trouble leaving the pits
sounded awful like the drivers literally didnt know how to drive. some of the other cars had a programmed pit idle [essentially a very fast idle] far easier to handle & NOT choke. essentially the tyres become the clutch when leaving. the audi diesel the epitome of excellence damn thing soooo smoooooth. the porsches racing at a distinct disadvantage, different class yet they have snagged an overall win on occasion. some of that technology filtering down to hi end street cars ill never be able to afford.
bend your mind.....
posted October 21, 2008 07:01 PM
Been mentioning this for years in the clutch discussions when people talked about how "weak" the 12 clutch was and how it "slipped". A 12 clutch will hold 500 hp without slipping. Do you believe me now? I gave up. The 1200 hp Turbo Can Am engines I built in 1973 had an 8 inch 8 plate clutch. An Indy car has a 8 inch or smaller clutch. The new clutches are carbon but the old ones were fiber and steel like a bike clutch.
If you, the driver or rider slips the clutch and overheats it, it's toast. If not it will hold all the power it is designed for. Clutch life is all in the technique. A driver who tries to slip these clutches can cook it in one try. That's why they light the tires.
posted October 21, 2008 09:40 PM
PICS? sounds interesting... must be made of good stuff
posted October 22, 2008 07:31 AM
Dr. Doug, SEEING is Believing! There is Just NO way to imagine something that small doing what it does! Yes, the clutch in a ZX12R is HUGE (Now) by comparrison!
posted October 22, 2008 10:13 AM
copied from Wikipedia:
Formula One cars use semi-automatic sequential gearboxes with six or seven forward gears and one reverse gear. The driver initiates gear changes using paddles mounted on the back of the steering wheel and electro-hydraulics perform the actual change as well as throttle control. Clutch control is also performed electro-hydraulically except from and to a standstill when the driver must operate the clutch using a lever mounted on the back of the steering wheel. By regulation the cars use rear wheel drive. A modern F1 clutch is a multi-plate carbon design with a diameter of less than four inches (100 mm)[citation needed], weighing less than 2.20 lb (1.00 kg)[citation needed] and handling 900 hp (670 kW) or so[citation needed].
posted October 22, 2008 12:47 PM
Thanks KZ, I did not know the diameter but 4 inches "LOOKED" about right but I just could not bring myself to say it was THAT small!
warbird
posted October 22, 2008 06:32 PM
Yeah.....but NOX isn't suprised.....................
NOX
posted October 23, 2008 05:53 AM
Tee hee.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 23, 2008 09:12 AM
flite leader
posted October 24, 2008 11:53 AM
no matter what you are talking about
4 inches is SMALL!!!!!!!
bend your mind.....
posted October 24, 2008 01:13 PM
For a 50 CC Dirt Bike about right., but for 800 HP Not in my Brain can this be true! You could put the entire clutch in you pocket and not look excited! Like I said, I have a NEW Appreciation of F-1
NOX
posted October 24, 2008 04:14 PM
There is so much more to clutches. Size is a factor, but there are many more, that can affect things, and actually make the size not so much a huge factor.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Texas12R
posted October 25, 2008 02:44 AM
strange analogy.....my dads finger isnt that big ....but I know whats behind it .....
a GREAT deal of force.....It kept me from slipping for years
NOX
posted October 26, 2008 04:41 PM
Very good analogy actually.......
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
0.40742111206055 seconds processing time
