BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Bike Wattage NEW TOPIC NEW POLL POST REPLY
thekaz
spell chequer is bustimicated
posted October 14, 2008 08:45 AM
Bike Wattage
Does anyone know the wattage draw of a 2001 A1 while its running ?
I am trying to calculate how much extra alternator wattage is left over while the bike is running becuase I was thinking fog lights and heated grips......
woppi
posted October 16, 2008 10:26 PM        Edited By: woppi on 17 Oct 2008 06:26
manual info: 14,2V - 15,2V at the controller
your fog lights + heated grips should work without any problems !!!
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
ZXLNT
posted October 17, 2008 03:15 AM
Thats voltage, he needs to know wattage. How much current the alternator is able to provide..
thekaz
posted October 17, 2008 06:49 AM
Actually I already know the alternator has an output of 35amps or approx. 500watts @14VDC. I wanna know how much of that 500Watts is left over after you subtract the power used by the bike ( FI system, Ign system, lights, guages etc. )
Texas12R
posted October 17, 2008 08:00 AM
Mr Hill should have that info......Im curious too, because some people have trouble running
aftermarket headlamps that are hight wattage than the 55? watt oem lamps
RidgeRacer
posted October 17, 2008 12:13 PM
Why not measure it?
Pull out the the fuses one at a time and put an Amp Meter across the terminals and measure the the amount of current while the bike is running and hot (fan current) with the brake lights on. Then add up the current from the individual branch circuits to figure out total current.
thekaz
posted October 17, 2008 01:05 PM
Why not measure it?
Cuase I am a LAZY AZZ :P
I was kinda hoping someone would just know the amperage draw measurements.
I do have all the gear needed at work just kinda busy right now
0.27423596382141 seconds processing time
