BIKELAND > FORUMS > ZX12R ZONE.com > Thread: looking for used muzzy lockup NEW TOPIC NEW POLL POST REPLY
2000redrocket
posted October 02, 2008 12:17 PM
if anyone has a used muzzy lock up clutch setup i am looking into getting one. i say muzzy cause it fits under stock body pannels.
thanks
posted October 02, 2008 12:58 PM
Paul Stuart. use the tool steel pull rods Nox had made up for it
2000redrocket
posted October 02, 2008 01:55 PM
kzscott :
how do i get ahold of him? it is used correct? still got my cell # ?
NOX
PMRA / TMRC Super Street 4022
posted October 02, 2008 02:12 PM
memberlist.....
stuartracing.
he may get to you before you read this.........
Pm me when you get it. I have a awesome tune up for single stages that will run 9.2s or better on stock motor.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 02, 2008 02:16 PM
http://www.bikeland.org/board/viewthread.php?FID=3&TID=40551
Stuart Racing
N.H.R.A . Dragracing.
posted October 02, 2008 02:38 PM        Edited By: Stuart Racing on 2 Oct 2008 22:39
I got a single stage MUZZY LOCK UP if you are still lookin.....Excellant shape...10 runs on it....
stuartracing@gru.net
Paul.....
Get with NOX for the killer setup to start out with, or almost right on...
2000redrocket
posted October 02, 2008 04:54 PM        Edited By: 2000redrocket on 3 Oct 2008 00:56
stuart i PMd u
kzscott what about the pullers should i pm nox?
tshultz
posted October 02, 2008 05:04 PM
I pm Stuart racing twice for ya 2000redrocket
posted October 02, 2008 06:28 PM
Paul can tell you about the pullers too. Nox's father in law owns a machine shop and is the one who made them
Stuart Racing
posted October 03, 2008 06:45 AM        Edited By: Stuart Racing on 3 Oct 2008 14:46
Yes, NOX is the one to see about the heavy duty pullers.....I got mine from him....I had a machine shop here in town make me one and the cost was $180.00.....That was the last one I asked them to make......BTW that one is STILL in my bike though....
Dennis, I have the lockup boxed up and waiting for your Postal m/o.....
NOX
posted October 03, 2008 04:52 PM
Paul had the only puller.
We could make more........
need the muzzy puller though........
Take the muzzy puller to any machine shop, and they could make one for probably 50 to 100 bucks, Paul got robbed for sure.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
2000redrocket
posted October 03, 2008 05:32 PM
stuart check is in the mail.
nox can u explain why the puller and soforth. does it not work stock?
posted October 03, 2008 05:52 PM
you need a longer one cause the spacer puts the cover out further. the muzzy ones are junk. mtc makes great ones, but only works with their lock up (thicker spacer = even longer rod) the ones that were custom made for the lock up by Paul or Heath are awesome and are sized for the muzzy lock up.
NOX
posted October 04, 2008 05:23 AM
Muzzy machines the tip of thiers, makes it weak, they put a hole in it that does not need to be there, and makes it thin wall. Just a faulty design.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
2000redrocket
posted October 04, 2008 08:04 AM
are we talking about the tower piece in the pressure plate or the piece the cable goes on to?
posted October 04, 2008 08:57 AM
the piece that goes in the pressure plate. you use the stock piece that goes in the cover for the cable
2000redrocket
posted October 14, 2008 05:25 PM
paul i got it today. thanks.
JACKSHOW
posted October 14, 2008 06:46 PM
I would use the outer support from MTC with the Muzzy lock up, bulletproof.
ninja12
posted October 14, 2008 09:29 PM
Muzzy sells a support if you ask for it.
Not on thier website.
Stuart Racing
posted October 15, 2008 10:25 AM
Excellant.....Let us know how it eventually works for you once you get it set up to your liking,ok....Good luck with it.....
Paul....
NOX
posted October 15, 2008 04:02 PM
Truthfully, they should give you one for free, since it should have come with it to begin with........
If you need a good tune up for your set up, PM me and I will hook you up , where it will be nice and smooth, and you can throw away the clutch.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
2000redrocket
posted October 17, 2008 05:33 AM
what is the support for? i am not spraying just sick of my mph all over the place at end of track. and now it is the next step in bigger motor.(though need the basket before anything relating to more hp)
Stuart Racing
posted October 17, 2008 06:57 AM
Since the puller is so long now the support helps to support the end a little...
NOX
posted October 17, 2008 03:19 PM
Your MPH is probably all over the place, because of inconsistency in 60 and 330 ft.
A good tune on a lock up will fix that, and keep your mph within 1mph each pass, weather staying the same........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted October 18, 2008 10:26 AM
yeah, if you mess up the first part of the run, you wont get the normal mph. trust me, been there done that lol
0.24824118614197 seconds processing time
