BIKELAND > FORUMS > ZX12R ZONE.com > Thread: cold starts NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted October 11, 2008 12:13 PM
cold starts
when i start my zx12 it usally takes three trys to get it started... i was wonderibg if there is any reason for this also when it does start i hear this high pitched humming noise i think that is is something to do with the fuel but im not sure
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
kaw12
posted October 11, 2008 12:20 PM
sounds normal to me
johnnnyboy
08 Concours 14
posted October 11, 2008 03:25 PM
yep same here
posted October 11, 2008 10:04 PM
the high pitched humming noise is the fuel pump pressurizing the fuel rail. wait till that humming stops before hitting the starter, maybe it'll start on 1st try.
krexken
posted October 11, 2008 10:21 PM
One thing to remember, no matter how long you wind on the starter, the injector only squirts one time!
shiggsy
posted October 13, 2008 04:46 AM
Is this correct ? I can't believe this is correct. If they only fired once what's the indicator to tell the ECU the engines running and resume injector firing ?
My experience with this (A2 model) when I had a non-starting bike I had the throttle bodies hanging to the side of the bike so I could see with my own eyes that the injectors were firing, on first crank all injectors fire simultaneously and from then on they take up their independent firing (according to cam and crank sensor I suppose).
posted October 13, 2008 03:55 PM
My Muzzy piped 12R would exhibit that trait if I didn't have the power commander installed.
Megabyte
posted October 13, 2008 05:28 PM
sounds normal to me
+1
posted October 13, 2008 06:28 PM
cover up half of the exhaust with your hand when you go to start it. you are turning the fast idle lever on right?
krexken
posted October 15, 2008 05:25 PM
Okay. Maybe I'm not correct. I only noticed the injectors firing once on the bike I was working on. Weird. I wound on the starter a while and the plugs never got wet. Perhaps the fuel pressure was bled off after the first squirt?
0.27107000350952 seconds processing time
