BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Reflashed my ECU NEW TOPIC NEW POLL POST REPLY
rgeorge
posted September 13, 2008 10:00 PM        Edited By: rgeorge on 13 Sep 2008 23:07
Reflashed my ECU
I disabled the speed limiter and raised the rev limit to 12000. After reflashing, the bike started and ran perfectly. I didn't brick it!!
If its not raining tomorrow, I'll go do a high speed run to verify the limiter changes work.
I haven't changed any fuel or ignition values yet, but plan to soon.
Thanks to Ridgeracer for all the work he has done!. His documentation made it easy.
rgeorge
posted September 13, 2008 10:15 PM
My notch:
Its doesn't look as nice as the ECUs RR has notched, but it works. I am worried about corrosion and moisture so I only uncovered enough of the board to install the connector.
posted September 14, 2008 06:45 AM
nice!
2000redrocket
posted September 14, 2008 11:17 AM
if there is any copper showing get a sharpie black magic marker and color the copper black and you are good.
welcome to the madness.
i got my lower rpms good but found out the upper rpms are lean say 5000 and up twards 8000. driving there to check it out is hard to do.
get a data logger.
what year is your bike?
posted September 14, 2008 11:41 AM
he logs everything now
2000redrocket
posted September 14, 2008 05:11 PM
so i am sitting here now going over my log for today to get it richer in the not legal areas to ride. the hardest part is figureing out which area to boost up to ritchen the problem area.
i am about tp copy and paste the stock map from 4200 to redline in the density map just to look at the log and compair.i will get it. but this time there is not a wow look at that place.
rgeorge
posted September 15, 2008 06:04 PM
My bike is 2003-B2 model
Yup. I log several things, but not everything
I am looking forward to doing some real tuning.!
2000redrocket
posted September 18, 2008 02:11 PM
the hardest is where in the density map to add or take away fuel according to where you are in the vacume colums.
i fixed my muxxy syndrome as well as possable. it now stays in the 13s or low 12s when you pull throttle instead of going 10 to 1 and shaking the chain in half ayt the2000 to 2600 area.
things i know. if you are rich 3000 to 4000 it is in the -22 cmhg ( i am 16/44 gearing and stock gearing may still be that or require you to pull more and it could go to the -18 colum) colum mine was stupid rich there.
i put the stock density map in from 4200 to 12600 and wow i got to lean it out. it goes 11.8 at 4100 hits 10.8 before 5000 then gets a tad lean at 14.2 twards 6000. this is by the way just maintaining steady rpm and or pulling just enough to get it to accelerate slowly to stay in the density map.i am shooting for 13.5 steady driveing. i have picked up 3 mpg this way. i guess for bikes wego says like 12.8 wide open 13 to 14 to 1 steady cruising lower rpms.
Operating Mode
Recommended AFR
Cold Start (first 30 sec)
11.5-12.5
Idle
12.8-13.5
Part Throttle Cruise
13.0-14.0
Wide Open Throttle
12.5-12.8 (values down to 11.5 may be used to reduce detonation)
0.36380290985107 seconds processing time
