BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Do Muzzy stacks work?? NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted February 09, 2008 04:34 PM
whats the difference in the lengths and do they work,, if so are the gains noticeable?
posted February 09, 2008 07:05 PM
Yes...
well I have Bear stacks and they work Great! 2+ hp when tuned...
twista
posted February 09, 2008 07:21 PM
are yours the stock replacements or are they long or short? and is your bike stock? PC3?
hyper12r
posted February 09, 2008 07:30 PM
i used to have the blue stock replacement muzzys stacks... gain 2bhp ..felt difference.
basic bolt on mods,cam spockets,pc3,full system,bmc race,blue stacks,advancer,high comgasket...
shiphteey
posted February 10, 2008 07:53 AM
I have 4 short bear stacks in my bike. Can't say I "felt" the difference but the general consensus is that they seem to help up top so I went with them. I went a little faster with them, but that was a different day with a slightly different set-up.
Gemini Motorcycles
Phantom13
posted February 11, 2008 10:07 AM
The Muzzy stacks are "ok"... I'd go with the Bear Engineering stacks instead, much higher quality and Vincent Hill (the only North American distributer) is a pleasure to deal with.
They come in 3 variations: Shorts, Longs, Mixed
The type that will work best for you will depend on your engine and intended application.
"The only place Success comes
before Work is inside the Dictionary."
  Ignore this member    Click here to visit Phantom13's homepage.
Megabyte
posted February 11, 2008 01:33 PM
I'm running Muzzy's gold stacks on my 212rwhp 1361. We didn't do a back 2 back, so can't say how well they work.... I think I'd go with Bear's stacks next time, just because people I respect on this board think so highly of them...
NOX
PMRA / TMRC Super Street 4022
posted February 11, 2008 07:36 PM
Mixed Bear stacks on mine. Had to change my lock up tune a slight bit......., so yes , they made a difference....... I had to add about 5lbs of static pressure.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted February 14, 2008 04:48 PM
The "shorts" are essentially stock length. The "longs" are (I think) 3mm longer and should help bottom and mid range a bit (with a small sacrafice on top, of course).
It's interesting to note that Muzzys never sold those parts with ANY promise of a power advantage. They are simply a tuning tool for moving peak torque a little and making the whole installation a bit cleaner.
posted February 14, 2008 08:19 PM
anyone who has looked at stock stacks up close knows they have a smaller ID than the throttle bodies though. its not much, but matching them up(either with a dremmel, or replacing with muzzys or bears) cant hurt . its gotta help a tiny bit, and like DM said, different lengths let you move the power around
posted February 15, 2008 02:58 PM
You are right. Can't hurt. But no gains were ever promised.
Megabyte
posted February 15, 2008 04:21 PM
If memory serves, there were back2back runs w/bear stacks showing more power, and, even stretching my memory more, I seem to recall reports that bear's stacks made more hp then Muzzy's.
posted February 16, 2008 09:00 AM
That was reported. We could never duplicate that , though. We obviously had some Bear stacks and cross- tested. I don't think there was any data to hang your hat on except for the aforementioned torque shift.
I use them, of course. They 're nice parts, are certainly part of a sano build, they seal better on a turbo, and hey, they look cool when the engine is on the stand.
NOX
posted February 16, 2008 12:58 PM
with no pc, and a brock pipe , 124 mph in the 1/8, with bear mixed stacks........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
BEAR
posted February 18, 2008 02:43 AM
Thanks Doug ,But the stacks were given to Dan to test and he got 9-mph on top end with just a swop of the stacks , Stacks can not work on the dyno as there is no air flow We always say you are lucky to get any Hp on a Dyno but there is a big difference on top.I still haven't figured a way to prove it but the exercise that dan did seem to prove the theory
As far as the design go,s I dont know If muzzy just copied it or did his own test, the flow profile inside took me 3-months to show top end speed ,and 165 different angles not just a radius
BEAR
7.56@195 Worldfinals 2004
7.43@ 194 Britol 2008
  Ignore this member    Click here to visit BEAR's homepage.
oldkawboy
posted February 18, 2008 07:37 AM
Bears stacks work and are easily worth the money.
Me and the boys were lucky enough to be involved in the early testing of the short stacks at Maxton years ago. I'm sure there is some guys who were not around here years ago so I'll give a quick run down.
All three of us were stuck at 198-199mph and within a short window (maybe 30-45minutes) we swapped the stacks with no other changes on the bike. On the very next set of passes we all ran between 202-203. We flatly ran out of time to swap back since the event was over but there is no doubt in my mind and the folks that were there that the stacks made the difference. The weather condtions stayed the same so that was not a factor and for all three of us to pick up that kind of speed it was no fluke.
We also have ran Bears stacks in our ZX10's with great results.
Bear does his homework and his longer stacks as mentioned will move the torque / hp
around for street & strip duty.
If Bear stacks were available for the 14 you can bet me and Zack would have them on our bikes, along with a ton of other folks.
I've said it for years and am very sincere............BEAR IS THE MAN!
Dan
posted February 18, 2008 02:49 PM        Edited By: dougmeyer on 18 Feb 2008 14:50
Whoa there. NINE mph? That would take about a 14% HP increase (25 on 180hp)
at 200 mph. I like Dan's example better, but it's still not a valid test. Using his results you're talking 11 hp.
I would also suggest that if they work in motion they work on the dyno. Remember, ram air doesn't change the airflow into the engine, it only changes the density of the air that's flowing. The power goes up because you are putting more oxygen into the same space (cylinder) each inlet stroke and thus can put in and burn more fuel. This enables continued acceleration (up to the rev lmiter, of course). The continued acceleration allows the rpm to continue to rise (because the point of power/drag balance is moved "up" and you should get a higher top speed.
My point is that if a change is made to the FLOW capability (which you all suggest the stacks do to quite a large degree) then that increase in flow will be the same no matter what the density. Power on the dyno with atmospheric pressure will go up x% when the stacks are installed and the base power with higher density (ram) air will go up by the same % when the stack are added.
I haven't changed my feelingss on this since back when the stacks were under development. That's because the gas laws and laws of physics haven't been re-written as far as I know.
Y2, Whaddaya think? Am I wrong here?
Great to hear from you, Bear. I miss seeing you guys. How's things on the bottom side?
oldkawboy
posted February 18, 2008 03:47 PM
I'm sorry our test was not valid to you Doug but I did exactly what Rob Muzzy asked me to do when he shipped Bears stacks to me. He stated to make our passes and then change out the stacks as quickly as possible with no other changes to the bike or the engine, which is what we did.
After our results you told me that the runs must have been done later in the evening when the weather changed, which wasn't the case or that I may have done something like move my shoulders around to gain the extra mph, which I didn't do. I do know that in a perfect test the stacks should have been swapped back to the originals and re-run but unfortunately time did not allow this but with three different riders on the same bike with identical results, that is a valid test in my eyes.
While I realize I cannot compete on your level as far as physics, gas laws, etc., I do have walking around sense and I for one believe Bears stacks work.
Oh yeah, I'm also thinking that Bears short stacks were shorter that the stock stacks but it's been a long time since I looked at them together.
Dan
NOX
posted February 18, 2008 08:54 PM
It says Muzzy, we must all be wrong.
Kurt says so.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted February 18, 2008 10:10 PM
Dan, I remember all that as well as you. I don't quibble a bit with your recollection. It just not a valid test, that's all. I don't doubt for one second your results, just the reason they occured. How could so many other people put those things on and not get anywhere near the improvement. Hey, I'm beginning to sound like someone else around here......
Come on you guys, you've all worked on this stuff long enough now to KNOW that a change in a couple mm of inlet length simply cannot "add" that kind of power. You work VERY hard for 10 hp and 1 or 2 mph.
I don't think the aluminum stacks can be materially shorter than stock, as that distance is determined by the distance between the injector body is and the bottom of the frame. THey are basically just about stock length and maybe 3 mm longer.
As far as the optimum radius of the entry, agin not some black art. The aoptimum ram recovery and minimum restriction to flow into a tube occurs with a "lip" radius of 50% of the diameter of the tube. This is why you see such large "mouths" on inlet stacks. Anything less that reduces the effectiveness of the inlet stack.
Ever see those tall stacks on an injected big block and how they are splayed out at an angle? That's so you have room for a generous radius on the entry without interference between the adjacent stacks. In fact, sometimes it's worth varying the lengths just to accomodate the radius at the expense of length because the entry is more important to total air flow.
NOX , I've got absolutely no personal axe to grind. FOR fuck sakes I'm telling you that the Muzzy stacks DON"T do anything remarkable not that they're the same or better. I've had both brands in my hand. They're nice parts but not magic bullets. Jeeze.
BEAR
posted February 19, 2008 12:56 AM        Edited By: BEAR on 19 Feb 2008 01:06
This is the big reason I do not get involved on the net as every body wants to be the man and the sun can not shine over the next Guy
The stacks we made I made in 2002 work Period , as we did not make them to sell it was for my own bikes,At Gainesvillein 2002 i showed them to Rickey and Muzzy saw them At that stage they(Muzzy) was running the OEM rubber Stacks??And Rob wanted to test them and knew it would work for the turbo bike.I gave Rickey 2 sets
I gave Vincent Hill as set and the was it
Muzzys did not test the stacks they sent them to DAN to test ,and that is how it came about that we started to make the stacks on order when Dan confirmed that they work.
Our results showed that at 1650 m above sea level 3 to 5 Hp on the dyno and the 1/4 time improved back to back as Rickey rode the bike here In SA and He confirmed it
Then In Nov at Gianesville we made 20 sets for Vincent and to sell at the World finals ,and guess what Muzzy had made stacks the same as mine Just the color was diffrent ,And Rob told Eric fro Porto Rico that the Muzzy stacks were better. But he had never tested them????
Muzzy stack are a copy of the Bear Idea and Doug you know that , as the the design ot the same ,they have not been tested anywhere as did with mine, now the facts are disputed . I dont care about all the theory ,and I will not give all our infomation away why they work . Dyno a bike with ram air in a wind tunnel and see what you get. Bear is an Engineering company that do not make a living out of manufacturing of bike parts ,we make High tec stianless steel pumps and parts for Aircrafts , the bike parts we make is for our own use
We have made:
Titanium sleeves for Zx12
zx12r stacks
zx10r stacks
zxr 14 stacks
zx12 billdet barrels
zx14 slider clutch
Lock up cluch zx12, zx14 ,zx10
wheels zx12, zx14 zx10
Yoke and triple clamps zx12,zx14 zx10
Swing arms Zx12 zx14
and many more parts as thes are the bike we race and we have been ripped off to many times
We made these parts for our own use and only because we love racing.
It seems the stuff works as we have not done bad we are currently #2 in SA,and we have run 7.56 @ Gainesville on a local build bike, and there is only one other kawasaki that has gone faster than that.And no other privateer
All thanks to Vincent Hill, Rickey Gadson, Dan and Son a small amount of people do have our stuff for the love of racing not profit
Dan I do have Zx14 stack that I will send you, But they are not for sale.
Bear
posted February 19, 2008 04:47 AM
To everyone, this is passion! I think that Dan got a 4 to 5 MPH Increase in top speed which we realized would take about "9" HP for that amount of Increase in speed. Second, the "Short" bears Stacks are 5 MM SHorter from the top edge of the bellmouth to the bottom of the stack as compared to the Distorted Rubber Stacks. The ZX14 stacks are truly something, but there was just no way to "EASILY" install them by the average owner, and the time and money to Make and develop them was just too high to sell them and have them copied by someone else for them to be sold to the Public. Dan, you are TRULY Getting the Hen's Teeth! make sure they are kept under wraps!
Last, even the Crooks know Bear Stacks. Last year in late February Bear was bringing in 20 sets of SHort Stacks for me to pick up in Daytona. They were all stolen in New York out of his luggage and have NEVER Been seen since!
BEAR
posted February 19, 2008 05:07 AM
Good to hear for you Vincent enjoy Daytona
NOX
posted February 19, 2008 05:43 AM
I was not making a comment on the Stacks, I agree that muzzy never advertized any gain.
I was simply making a comment on the customer service behind the phone lines up there. Those two guys NEVER admit any wrong. I was wrong for pulling my clutch at about 15 mph in the pits, and thats what broke it. Kurt and Dave called that "high wheel speed"
Behind PMs, Rob will, and ask you to quietly send him a personal email, but never publicly admit, that he gave money back to a lot of customers, for putting out a product that failed, and could lead to severe engine damage with the rods on thier lock up clutches. Dont get me started on the tons of regulators they sold that were set way too high on the psi for the switching valve on the air shifters...... Kurt said it was my Brand new Nitrous Express guage that was wrong.......
I was just making a comment about Kurts attitude in general, not towards you.
My apologies if you took it wrong.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted February 19, 2008 06:19 AM
Bear, could you give your oppinion on the silver stacks in these pics? they are shorter than yours and were supposed to work even better at higher rpm than your shorts
Doug, I would be equally interested in your opinion
pics stolen from this thread http://www.bikeland.org/board/viewthread.php?FID=1&TID=29648&pagenumber=2
All times are America/Va [ This thread is 4 pages long: 1  2  3  4     Next» ] < Previous Thread     Next Thread >
0.38203692436218 seconds processing time
