2000redrocket
posted August 23, 2008 04:42 PM
anyone intrested 2000ecu i'll setup rpms andmap
anyone intrested in a 2000 ecu with the rpms boosted to whatever u like and my muzzy pipe tweeked map? i am putting out feelers. this map will make your muzzy piped bike run much better and is for my bike safe id say. u should check your bike on a dyno that can load the rear tire and get it checked to be safe.
my map has the rich spot 2000 to 2600ish much better to ok. it will dive rich from time to time there but not noticable like before stock. and the rich driveing area 3000 to 4000 is better now.
the map is not perfect but much better. i got the hesitation ritchened up better off idle in 1st also.
if anything i can keep it stock and give whoever rpm they desire.
i only have 1 2000 ecu when i get time to mod it.
2000redrocket
posted August 24, 2008 06:13 AM
did i say i got 39 mpg with 16/44 gearing? close to 17/46 gearing.
zx12dak
posted August 30, 2008 05:24 PM
Hey Redrocket. Was that MPG on the highway??? I have been getting 33-36 with mixed driving and 37+ on the highway. Just curious. Did you put any timing in that yet?
2000redrocket
posted August 31, 2008 06:08 PM
i did not do timming yet. i am getting it (fuel milage)in sort of mixed driving. last was 38.5 with less longer driving.i have a advancer at 2.5 advanced though allready. there are two things i want to do next.
in compairing all 4 cylinder maps to the stock map for my year they are not the same differences. i printed out all 4 compair maps for each cylinder and am going to even all out. i know how it happened. my older IBM laptop is not the fastest thing and say i want to go up five numbers richer i hit up arrow 5 times. then later i noticed it does not always move the number up.
and today i was in a hurry and had mt bike at 90 to 100 on speedo and the 5000 to 6000 rpm steady up hill (slight grade) or pulling a bit at those rpms makes it go 15 to 1. i need to fix it even though you can not ride that fast steady for long. when i got to my brothers i unplugged the wego3 power so i can down load it and look at where it goes lean. i want to fix it and not get a ticket.
tecknickly (bad speller) we all lean our bikes out with a pipe at most places. it should get the same or better milage with out beating it.
i topped out 5th yesterday to check the wide open afr and it is rich on top at 13.2 to 13.1 i hit 119xx in 5th. i was moveing. i also want to look at my ram air the logger still showed no neutril or positive boost.
posted August 31, 2008 08:06 PM
higher than 13:1 is not rich, its lean. shoot for 12.6:1 to 12.8:1 dont melt it!
2000redrocket
posted September 01, 2008 06:06 PM
the dyno guys seem to go for 13.5 even for dynoing engines.
posted September 01, 2008 06:57 PM
what dyno guys???? im srry but 13.5:1 is way too lean
ask JC what he tunes motors for... i bet you will get 12.8:1 for an answer if its NA. richer if you are running nitrous/turbo to keep it cool... i mean, he is the builder and tuner of the fastest NA ZX12R in Texas, and runs a turbo busa..... ask Gary about the daily driver 1375cc ZX12R that JC put together with an 80 shot of nitrous....
zx12dak
posted September 01, 2008 07:33 PM
13.5 is kind of lean. My dyno chart is around 13 I think.
ninja12
posted September 02, 2008 09:17 AM
Sounds like your dyno guy don't know or wants you back as a repeat customer.
Lean is great for fuel mileage, bad for pistons, rings , bearings and power.
2000redrocket
posted September 03, 2008 02:19 PM
Edited By: 2000redrocket on 3 Sep 2008 15:22
i am talking my 600hp car. maybe car engines take leaner before "melting". i am happy driveing around at 13.0 to 1 though for now unless u guys change my mind i do not mind seeing high 13 when tooling or putting around. a car runs 14.5 or so when in open i am told. when i stand on it it goes low 13s or high 12s.
the guy building my engine on the dyno for the roundyround engines said 13.5 or so.
fattening it up is easy since i am happy i'll just hilight the chart in the driveing area and go up 2 to 3.
if you can ride a carb bike with the needles too lean and feel the slight surge and the slight hesitation and not melt it i would hope to be correct in saying with it running good it is safe. who knows what your old zx11 was at when you got the needles one washer above where it was not guite happy. now we got all this data and we know. i bet the almost good but a tad too lean for fealing it surge is 16to 1.
doug what do you think?
i am not pisse dat anyone saying i need to be 13.0 or lower or i will melt but if it is ingnorence (can't even spell it i bet) it has been running good, gets 38 to 39mpg and has been doing it on 100+ mile rides in the low to high 13 to 1s. i would never say 14.0 is good wide open hard load.
at the track i was shooting for 13.5
a joke i heard truck puller i got heads from is leaner is meaner till you stick a exhaust valve in a guide.
2000redrocket
posted September 04, 2008 03:18 PM
looks like i should keep itwhere it is at wide open throttle.next time at the track i am going to tow so i can look at it.
tshultz
posted September 04, 2008 03:29 PM
quote: looks like i should keep itwhere it is at wide open throttle.next time at the track i am going to tow so i can look at it.
sept 12 are you going to the track give me a call
2000redrocket
posted September 06, 2008 09:59 AM
here is the all out to 5th rpm and afr.
tshults if it is not raining again i will be there.
