posted September 01, 2008 06:46 AM
quick motor question
do i have to fully remove the motor to take out the stock head bolts to replace with APE studs, or will i have enough room by just tilting the motor down by leaving the lower rear bolt in the frame/motor?
thx guys!
kaw12
posted September 01, 2008 07:00 AM
i took the head off mine by just tilting the motor.
posted September 01, 2008 07:38 AM
thats what i needed to know! thx
posted September 02, 2008 10:21 AM
If you've got it that far, why not put it on the bench and do it right? (Pull the cylinder, inspect the pistons, chase the holes, clean the threads, etc. (I'm just sayin'.....)
posted September 02, 2008 12:53 PM
quote: If you've got it that far, why not put it on the bench and do it right? (Pull the cylinder, inspect the pistons, chase the holes, clean the threads, etc. (I'm just sayin'.....)
takes 2 hrs 20 min to put the motor on the bench, about 6 hrs to put it back (with some beers)
I am with Doug
posted September 02, 2008 02:41 PM
no spare headgasket here, and im racing this wknd. plus if the parts arrive for dads motor ill be putting that together for this wknd too. oh yeah, i have to finish and test my nitrous kit too. just not enough time. it will get torn down at the end of the season. im in Canada, so cold weather is coming up soon
if i had torn down and rebuilt as many motors as you guys, i wouldnt think twice, but please remember a little over a yr ago i didnt know a stock clutch basket wasnt a muzzy cutch basket. (remember that thread :P )
shiggsy
posted September 03, 2008 01:02 AM
Edited By: shiggsy on 3 Sep 2008 02:03
You don't even need to tilt it, I've had the head off loads of times and never needed to.
posted September 03, 2008 08:48 AM
You're a quick learner, KZ
But if you are so short of time why are you bothering with the studs? The stock bolts are very good unless you're getting awfully carried away with the juice.
Yeah, you can do that shiggsy, but WHAT a pain. You must have teeny tiny hands........
posted September 03, 2008 02:33 PM
1287 with a 60 shot. you think it will be fine till i go bigger? i really want those extra 7 or so ft #s of torque holding the head down. there isnt much gasket on a standard bore spacing 86mm block. im trying to play it as safe as possible
ninja12
posted September 04, 2008 11:13 AM
I remember when the word was Coby ran the 1287 with 100+ shot.
60 is not that big of a shot.
posted September 04, 2008 01:55 PM
I don't have enough personal nitrous experience to say. I'll let others comment.
wolf racing
posted September 06, 2008 02:33 PM
KZ,
We have used stock bolts with wet progressive 130+ shot for over two years. No problems what so ever with stock bolts.
Pro bike uses stock bolts also. No problems.
The stockers we have fitted 40 to 60 shot dry have had no problems either.
Just for info and maybe save a few bucks, on our N2O bikes (ours and customers) we use stock bolts (all), stock piston rods, stock valves (ti springs and retainers), stock buckets. But, we spend on flowing the crap out of the head. If the engine can breath out, things are a little better.
Wolf
Never Ever Give Up
posted September 06, 2008 02:42 PM
ok, thats good to know. Ill wait till this winter to do the install. i have them sitting on the shelf still wrapped up the way M Mike packed them
the head was milled .005" to clean it up and the 86mm block was fresh from APE, so everything "should" be flat and well sealed.
i spent quite a bit of time opening up the EX ports to match the gasket, and smoothed everything out, nothing professional, but a big change from stock
