2000redrocket
posted August 31, 2008 06:11 PM
when on ramair boost?
for all you data logging people at which point either rpm or mph does your map sensor show neutrial or positive boost.
johnnycheese
posted August 31, 2008 07:01 PM
ram air starts at about 38mph
rgeorge
posted August 31, 2008 08:04 PM
I've only done a few runs logging inlet air pressure. If I remember correctly, pressure didnt match ambient until about 175+ mph. I haven't been fast enough to get a significantly positive reading.
spdprorcng
posted September 01, 2008 10:02 PM
Old SportRider mag test with Pi system data acq, ambient match on BUSA was around 145
psycho1122
posted September 02, 2008 06:57 AM
JC is correct here,
My testing (00' 12R) revealed that the Ram Air system "overcame" vaccume in the airbox at WOT by 40 m.p.h. - THAT"S HUGE!!.
Pressure above ambient builds between 120-150 mph (depending on conditions) and boost is about .4 - .5 lb.
02' and up, Hans snorkels sacrafice boost for flow to improve low and mid power. My Hans picked up 4 or 5 h.p. on the dyno SITTING STILL. Lost pressure above 150 m.p.h.
posted September 02, 2008 10:16 AM
Psycho's got it right. Sort of. At what RPM was this W.O.T. ? How much air was the engine requiring when the pressure went to ambient?
Bottom line is that if you put the engine on a dyno with nothing but open stacks there will always be a "vacuum" above the stacks and it is not until you turn that pressure positive that any real gains in power will be realized. True, you are minimizing pumping losses by slowly neutralizing the low pressure above the stacks (in the "airbox")but that's not really significant. You need the increased pressure (correctly noted as significant at about .5psi @ 150mph) to gain power over what the engine is capable of producing under "natural aspiration".
posted September 02, 2008 12:58 PM
I love this kind of discussion but those providing data, please distinguish between airbox pressure and manifold air pressure (as DM is doing).
BIG difference in when they go to ambient.
spdprorcng
posted September 02, 2008 03:21 PM
Edited By: spdprorcng on 2 Sep 2008 16:52
Doug you may remember this from way back
No goofy water tubes either, data acq using MAP sensors to airbox
http://www.sportrider.com/tech/146_9912_ram/index.html
On another note did you get involved with the old Dynojet EFI using a
MAF sensor on your zx11"C" or was that one of the Muzzy projects
around the time you jioned them??
johnnycheese
posted September 02, 2008 06:08 PM
quote: JC is correct here,
I knew this back in 1990 with no pressure sensors either
posted September 02, 2008 07:28 PM
A couple of things here.
I ran my own simple pressure gauges zip tied to the instruments at Bonneville on the original ZX-11C to see what was going on. They went positive at 155 mph.
Is that what you did JC? I wouldn't be surprised!
Also, I had the ability to see the electronic data acquisition on the factory Kawasaki Road racers at Daytona (about 150 mph). And later, on the ZX-12, to get validation directly from Japan through contacts at the factory.
It all adds up to about 140-155 mph depending on the airbox and the air of the day.
By the way, You don't really need to do any of this to get close. It is easily computed from known qualities of air and the principles of Ram Recovery.
The ram pressure of the incoming air is approximately equal to the density (of that ambient air) in pounds per cubic foot, times the velocity (of the vehicle) squared, divided by 4311.
(one cubic foot of "standard" air weights about .076 pound). The ram pressure is the result of the inertia of the air when it is stopped or slowed by the walls of the airbox (and port inlets)
Because the velocity is squared, the pressure rise is not linear-the faster you go, the greater the rate of pressure rise.
The one thing that mostly effects the range of this is the shape of the inlet. This is what the testing is really aimed at- fine tuning the inlet shape.
rgeorge
posted September 02, 2008 09:50 PM
I suspect that my dirty airfilters caused a significant pressure drop. If I ran without filters, the pressure would go positive sooner.
2000redrocket
posted September 03, 2008 02:05 PM
well going by my map sensor on the wego3i was getting close to 76cmhg area but if you go on what the voltage is bike on engine off i was4 cmhg away from brakeing even on the engine side of the throttles. not air box pressure though i got a map off ebay i may put it in and watch it. it can go in where the kleen went for a first place then the dirty side last.
psycho1122
posted September 05, 2008 04:41 PM
quote: I love this kind of discussion but those providing data, please distinguish between airbox pressure and manifold air pressure (as DM is doing).
My testing ino at the time was a Multi-meter measuring MAP sensor voltage real time while riding the bike. I converted the readings using the graph for the sensor in the service book.
2000redrocket
posted September 05, 2008 05:29 PM
i also did that sort of. i put a vacume pump on my spair and wrote the voltages and inhg to convert to cmhg. well in my enginuity map it did not work that way for what ridge has in the density maps. but if it says this voltage on the meter i found out the voltage in will make the voltage go up or down.
map plugged in to my desktop colputer power supply since it was the only thing i had 5vdc was 5.20 in and out is 3.76 to 3.80 i have observed in the coarse of 2 weeks and i am thinking it is barmeteric pressure making that change. my place is about 430ft above sea level and i am thinking it should be 74.8cmhg where i am by the one chart. i have my wego3 set to the 1=10cmhg 4.2vdc = 90cmhg.the bike seems to sit around 3.65 but u can make it change lights on or off. i do not remember the voltage into the 12s map.
for science i am going to put 4 nimh AAs together and go for a drive to watch the map voltage. i am curious on the voltage change vs altitude. i know it says it in the manual but my math was never over alg1 in school so i am doing it hands on.
2000redrocket
posted September 05, 2008 05:46 PM
above is a shot of the all out run to 118xxx the red is the map sensor
2000redrocket
posted September 06, 2008 09:56 AM
that would be 118xx in 5th i do not think it was 6th.
