BIKELAND > FORUMS > ZX12R ZONE.com > Thread: gettin into neutral NEW TOPIC NEW POLL POST REPLY
Bobbydigital17420
posted July 17, 2008 01:13 PM
gettin into neutral
ive been havein trouble shiftin my 2000 zx12 into neutral while moving. the only way i can get into neutral is when im at a complete stop. wont go into neutral if im movin.
is this common with the 12's
  Ignore this member    Click here to visit Bobbydigital17420's homepage.
ZXLNT
posted July 17, 2008 02:15 PM
Yes, they have a positive neutral finder..
posted July 17, 2008 03:35 PM
you dont have a manual do you?....
Bobbydigital17420
posted July 17, 2008 04:54 PM
shifting into neutral
what is a positive neutral finder..
and i dont have a manual for the bike
ZXLNT
posted July 17, 2008 05:04 PM        Edited By: ZXLNT on 17 Jul 2008 19:44
You have a PM. Its really a pretty simple way of allowing the bike to find neutral when stopped. Basically 3 small 5/32 steel balls that drop into place when stopped keeping the gear from overshifting into 2nd. When your moving centrifugal force flings the balls outward into a groove that allow the gear to slide over the shaft..
posted July 17, 2008 05:19 PM
pm returned bob. happy reading(lots of pics too)
chango
posted July 17, 2008 09:47 PM
If you don't mind could you PM me the same info?!! It would be greatly apprecieated. The guy who had my bike before me replaced a shifting fork and it never had neutral again. I'm a begginer and not very mechanically inclined. But I'm learning!!
woppi
posted July 18, 2008 04:13 AM
the clutch working well ??????????????????????
if not ---------------------
woppi
1st TFA Member / Austria !
2000 Limited ZX12R NOS
gsxrassassin
posted July 18, 2008 05:39 AM
I noticed the same thing. With every other bike I've ever owned sliding it into neutral just prior to stopping wasn't a problem but on the 12R (2000 model) it is quite the challenge. I figured it was the way the transmission was built but it's good having the exact explanation.
GSXR
Over the hump, back up and running again!!
ZXLNT
posted July 18, 2008 08:10 PM
Kawasaki's have whats called a Positive Neutral Finder. Basically its 3 5/32 steel balls that fit inside the the transmission output shaft. When the bike is stopped and the output shaft is not spinning one the ball bearings drops down into 1 of 3 holes that is crossdrilled into the shaft. That prevents the transmission from overshifting from neutral into 2nd gear. When the output shaft is spinning all three balls fling outward into the holes and line up into grooves on the inside of the gear, allowing it to overshift into 2nd gear..
Or something like that...
gsxrassassin
posted July 22, 2008 09:33 AM
The other day I took the 12 out and waited until just before the bike came to a hault to slip it into neutral. It can be done but for all practical purpses by the time things are moving slowly enough for the bike to "find" neutral you're stopped anyway.
GSXR
posted July 22, 2008 12:40 PM
Kawasakis have had this feature since 1973.
The Positive Neutral Finder has no bearing on getting from 2nd INTO neutral, it only prohibits being able to select 2nd from 1st when the wheel is NOT turning. When stopped, from 1st you can ONLY get neutral. Downshifting from second into first either stopped or in motion is not changed and you should be able to select neutreal from 2nd if you have a good feel. Any difficulty in achieving this is usually the result of a dragging clutch either from mis-adjusted cable or warped steels.
The only reason to disable this feature is to allow starting a burnout in second without upshifting from first.
Doug
posted July 22, 2008 10:53 PM
Doug
Sorry Doug, there is a 2nd reason:
you have the trans apart, those fukken lil balls roll off the bench, hit the concrete floor and bounce into dimension X.
posted July 23, 2008 02:28 PM
hahahaha yeah allmost happened to me, but when it came back from Mark @R&D the balls were in a bag (trans assembled) so thats where they stayed. i find it much easier to find neutral with the bike off now. otherwise i usually go to second if its running. its no big deal holding the clutch lever in tho, i can hold it in with one finger since it has a NOX tune
NOX
PMRA / TMRC Super Street 4022
posted July 24, 2008 05:11 AM
Doug
Or, starting one in 3rd or 4th. When I ran a 7 inch slick, and 16/56 gear, I did 4th gear burnouts.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
NOX
posted July 24, 2008 05:15 AM
Exactly......
Mine are out too. You can get it into neutral while rolling, if you are good, and it goes to second with no issues at all......., will damn near go to 6th without the bike moving at all........
Disclaimer: One finger clutch operation not advised as safe operating procedure. Unless you chopped the rest off in a table saw.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
posted July 24, 2008 04:56 PM
yeah, i use 2 fingers, but i can pull it in with 1 lol.
0.25516390800476 seconds processing time
