BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 12r gauges . nz. NEW TOPIC NEW POLL POST REPLY
vinchensoo
posted February 23, 2008 03:13 PM
12r gauges . nz.
hi there ive brought a set of gauges off ebay 04 model .ive got a 01 bike .on the back of gauges are a set of wires leading to 2 black boxs that say epicenter on them ??? my old set dosent have this ... what is it do i need it . my old set was in kms new set now in miles ,i liked the white dail look is there any way to convert the odometer to kms
cheers
twista
" Get up, and Stay up ! "
posted February 24, 2008 04:08 AM        Edited By: twista on 24 Feb 2008 04:13
sounds like you have white face guages,, i think i might still have a white set in Kilometers left over,, i cant promise though,, those wires go to the relays ,, take both black wires and twist together,, and then both white wires and twist together,, then tap into the parking light with them,, (the little light in the front above the headlights that comes on when you turn the key on),, also known as running lights,, make sure you go power to power and ground to ground,, if you are interested in the white guage i have let me know and i will try to find it,, like i said though no guarantees! hope that helped...
what they do is stick on,, you peal off a back,, gotta be very careful,, it wants to stick to anything,, but there are notches where its supposed to go,, to a while to get the hang of it,, just be careful and youll be fine,, piece of cake!
vinchensoo
posted February 25, 2008 12:23 AM
thanks
thanks bud ,but these wires are attached to 2 little black boxs ,,do you mean i cut them and wire it in to my running light and ditch the boxes???? im sweet for the dials its also in kms shame thou the new set only goes to 180 mls old set was 340 kms (wank value)
i was wanting to change the total mileage to kms ,is there any way to wind the mileage back ,my bike had done round 15000 ks not 16000 miles the new one reads
cheers
twista
posted February 25, 2008 04:08 PM
NO DONT CUT THEM! those are the relays that go with the face plates,, after the come out of the relays is when you want to hook em up! dont know how to change the mileage..
tuusinii
posted February 25, 2008 10:26 PM
Removing mileage can't be done because it "burns" memory as miles go past. Or atleast nobody hasn't found a way to do it. Adding can be done by giving it fake signal.
0.38124918937683 seconds processing time
