BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Ring? NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted January 05, 2008 09:16 PM
Ring?
there is a ring nut (dont know what its called) anyone have a picture or know where to buy the wrench to get it off,, this is on the swingarm pivot shaft,, looks like the guy i bought the new one from used a screw driver and hammer to get it of,, it cant be put on the same way can it? round ring has 4 notches in it..
posted January 05, 2008 09:28 PM
you could probly use a hammer and punch/ screwdriver, but if you have a dremmel you could make a "funny" socket out of a socket the right diameter. or a chunk of pipe for that matter. just make the notches fit
did you see my home made valve spring compressor tool? you dont need a lot of the fancy kawi tools
twista
posted January 05, 2008 09:32 PM
yea i was just searching and i found the dremel one,, did you see the one made from an adjustable wrench? http://www.gadgetjq.com/steering_stem_adjust.htm
0.23272895812988 seconds processing time
