BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Clutch setup? NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted October 14, 2007 06:56 PM
Clutch setup?
OK after brain picking and numerous searches on this sites threads,, i have descided to go with this setup,, please feel free to chime in if i am screwing up in any way..
1. Falicon Basket
2. 02 hub and plates assembly
3. 12 2002 stock fibers and 11 1.6 steels
4. either 636 springs or some other stiffer type springs but not Muzzys due to bind when used in concert with stock stack height?
should this do the trick?...
posted October 14, 2007 11:48 PM
looks good, but i've never heard of Muzzy springs binding.
ZXLNT
posted October 15, 2007 01:46 AM
Me neither..
posted October 15, 2007 05:17 PM
my setup
MTC Basket
Muzzy Hub (for better oiling)
stock fibers
2.0 steels (thicker is better for heat dissaption)
6 muzzy springs
just mic everything to make sure the stack height is ok. you can use extra steels to build up stack height. my frictions were worn enough to put the total stack height too low, but they still were well within the service limit so i used a couple 1.6s in place of a 2.0 in two places to build up the total height. putting two 1.6s together is just like having a 3.2mm steel so it will take the heat even better
0.23733687400818 seconds processing time
