BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Chain and sprockets? NEW TOPIC NEW POLL POST REPLY
twista
" Get up, and Stay up ! "
posted October 07, 2007 06:21 AM
Typically how much mileage should i expect from a stock setup,, also can anyone recommend a replacemant setup,, (brand model etc.. gonna go with a 17 up front again) and is it linked or solid like the stocker and is O ring better,,, thanx
supra5677
posted October 07, 2007 06:45 AM
at least 30,000 miles
zx12adam
Member
posted October 07, 2007 06:53 AM
I got 18,000 out of the stock stuff.
CBR1000RR
Best Literbike: Performance Bikes, Superbike, BIKE, MCN, Road Racing World, and Motorcycle USA
twista
posted October 07, 2007 08:04 AM
shit,, i only got 12,000 on mine,,and it feels grindy,, what i mean is it doesnt feel as smooth as when it had less mileage,, i can feel the gearing thru the handlebars,, does that make sense,, could it be in correct chain adjustment,, or something else,, weird
posted October 07, 2007 02:05 PM
The KEY Word here is STOCK!!!!!!!!!!! 17 is not stock and bends the chain harder. STILL, If you Clean the chain with WD-40 and clean it off and lube the chain you will do a lot better! I used Alisyn which was great all SYN lube that went on thin and set up like grease and now I use BelRay that leaves a White Lithium Grease Coat. WHen the chain sits for a period there is no rusting as it does from the Rain and Hudmitity if you only use WD-40
Provenuts
posted October 08, 2007 12:05 AM
I thought WD40 is bad on O-rings and therfore should not be used on chains.
posted October 08, 2007 07:51 AM
OH Oh, YOU DOne it now!! There are those here that will Swear that is ALL you will ever need! They are partly right IMHO because a lot of the wear comes from Dirt and keeping the chain clean removes the Dirt.
Water Displacement Formula 40 is just that and helps to stop rust, It does not act as a cushion between the rollers and sprockets
0.2442638874054 seconds processing time
