BIKELAND > FORUMS > ZX12R ZONE.com > Thread: tough bolts NEW TOPIC NEW POLL POST REPLY
aliveagain
posted October 02, 2007 04:43 AM
tough bolts
I just had fun trying to remove a stripped out bolt on the duct funnel(velocity stack).I was just wondering who else had a bolt turn bitch on them.
Texas12R
posted October 02, 2007 04:02 PM
Those had locking agent on them from the factory, but Im sure yours have been out before.
I have often wished for graded bolts in all locations even though its not always needed
aliveagain
posted October 02, 2007 04:27 PM
The part that stripped was actually the nut on the underside tack welded to the flat stock piece.With the spacer plate on and the Muzzy spray tubes inside the air box that don't quite line up,the bolt probably cross threaded when I installed it last.Drilled and tapped it out for a heli-coil,and all set.I did have to use a belt sander to grind the end of the coil as it was too long.PIA! I'm slowly putting the motor in now.
posted October 02, 2007 04:31 PM
I bought NEW Brackets!! Cheap from ROn Ayers and keep a Spare set!
0.32237696647644 seconds processing time
