BIKELAND > FORUMS > ZX12R ZONE.com > Thread: tubo check list NEW TOPIC NEW POLL POST REPLY
jus1975
posted September 24, 2007 08:23 PM
tubo check list
For a turbo system, what is needed?
Say for instance a home built stage 1.
What do you do about air temp sensor? How does it operate when using a turbo?
If I use a t28 with internal wastegate, should I use it or should I weld it up and use an external?
ninja12
posted September 24, 2007 08:35 PM
tubos are no good try a turbo.
jus1975
posted September 25, 2007 10:13 AM
Whatever
What all do I need?
posted September 25, 2007 01:11 PM
Use the Search a LOT has been discussed about this and none of it was easy
posted September 25, 2007 05:46 PM
1. Dig a hole 5' deep
2. Withdraw money from your bankaccount and place in hole. (Smaller denominations take up more room.)
3. Repeat until full
jus1975
posted September 26, 2007 07:51 PM
I did some searching and I am not finding what I want to know. I have looked at some kits for other bikes as well and finding some with extra fuel rails and injectors and some with just notations of needing a PC. What I want to know is:
1. Do I need an extra fuel rail and injector or can I just make adjustments to the PC?
2. If I need another fuel pump and regulator and what type?
3. Does the extra fuel pump piggyback the factory or replace it? If replacing the factory does it go in the tank or is it external and how to you disconnect the factory fuel pump?
4. What do you do about the air temp sensor, does it stay in place or is it mounted to the plenum?
5. And any other info would be greatly appreciated.
By the way, the bike is going to be street driven with stock internals and pump gas. It has a plenum mounted inside the frame.
nox
PMRA / TMRC Super Street 4022
posted September 26, 2007 08:35 PM
Hmm......., plenum inside the frame...............
Fix to the big problem..........?
this tubo might work........, sorry, could not resist.......
I like the idea, but also, TurboBlew has a good point........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
jus1975
posted September 26, 2007 09:54 PM
Yeah maybe so, but back to the questions please. This will be a through the winter project so money is not the issue. I can save and buy the parts as needed.
TRNorBRN6001
posted September 27, 2007 09:48 AM
"Money not an issue", thats the best state of mind to start with. Small turbo for the street, just need a fuel pump (Check Muzzy). Muzzy Fuel Pump is a stand alone: remove tank, turn upside down, remove fuel pump and replace with Muzzy kit. Might need a spacer plate and/or pistons if you don't like to keep the boost low.
Be happy with 220-250HP!
Might be Air Pressure sensor your thinking of.
Good Luck and keep us up to date on that little winter project.
TFA 200MPH CLUB MEMBER!
jus1975
posted September 27, 2007 08:37 PM
Is that the Muzzy fuel pump that was an upgrade for 2000 model 12's and is equal to the newer factory versions. I have a 2004.
TRNorBRN6001
posted September 28, 2007 05:26 AM
Yep, upgrade for 2000. Can't remember what it flows exactly.
posted September 28, 2007 07:29 AM
It flows enough for 700 HP! If you are going to make more than that, then you need more Pump!
I do not know for sure, but Doug Meyer may still have his bike for sale! It was the one that set the record at Bonneville for Mike Corbin with Saddle Bags. I think the price is about $12,000 and with a complete bike like you have you will have any missing parts!
posted September 28, 2007 08:00 AM
Here's the link to the classified for the turbo package I have. Please PM me if you want photos.
This is absolutely the quickest most economical way to get an excellent turbo package.
$10,000, not 12. But I'll take 12.......
http://www.bikeland.org/board/viewthread.php?FID=3&TID=28436&set_time=
Doug
TRNorBRN6001
posted September 28, 2007 08:10 AM
Just sell your bike and pick up Mr. Meyers. It will save you money and headaches in the long run.
jus1975
posted September 29, 2007 07:36 PM
Cant do it. I love my bike. Just want to do a project for the winter.
posted September 30, 2007 03:26 AM
Maybe add to that what my Dad always said "Experience is ALWAYS SOmething you get immediately after you need it!" After this winter and Next Summer and next WInter, you will be experienced!
My next SUggestion is to call Mr. Turbo! He makes more Turbo Kits than most people and has EVERY Part possible that you will need!
posted September 30, 2007 08:59 AM
have a look at this http://www.zx-12r.org/phpBB2/viewtopic.php?t=47607
jus1975
posted September 30, 2007 09:55 AM
Thanks for the link.
Hey everybody, dont get it twisted, I now its going to be a pain in the ass. But I am willing to try and take on the challenge. Its just time consuming. Anything is possible. And with the support I get from this site, I know I can make it happen.
Vincent,
Can I use that quote. I like that. Because it is exactly how things are. You have all the experience you need after it said and done.
posted October 01, 2007 06:25 PM
I would love to see a detailed progress thread when you start, i want to build one someday....
0.33822917938232 seconds processing time
