BIKELAND > FORUMS > ZX12R ZONE.com > Thread: OIL COOLER/NEUTRAL SWITCH? NEW TOPIC NEW POLL POST REPLY
2 hotty
posted September 24, 2007 04:48 PM
hey i gotta crazy question again.....i want to hook up an oil cooler on my dwarf car, where do i need to hook the lines in? has anyone ever done it before? and one other thing, my car will not start unless it's in neutral, and that's a pain in the a$$ if i spin out or stall it. how do i by-pass it? any help would be appreciated. thanks..........................
ridgeracer
posted September 24, 2007 05:42 PM
The bike won't start unless the bike is in neutral or the clutch is pulled in. You need to either but a switch on your clutch pedal or hard wire the interlock switch to make the starter circuit think you have the clutch pulled in.
posted September 25, 2007 07:44 AM        Edited By: VincentHill on 25 Sep 2007 08:47
I am getting reado to hook up something like this myself! I think I am going to look at "Muzzy" for the Oil FIlter Kit that they use to move it for the Turbo's and it may have the Oil Lines hooked to is also. $167.95
2 hotty
posted September 25, 2007 09:24 AM
where can i find the interlock switch and what does it look like? and isn't that just an oil filter re-locater? or can i use that to hook up an oil cooler?
shiggsy
posted September 25, 2007 10:20 AM
On the A2 model a wire to ground from ECU wire 23 (Green black) disables the interlock functions.
posted September 25, 2007 01:10 PM
Exactly! It is an Oil Filter Relocator! What goes in between the Block Off Plate and the Oil FIlter Bracket?? "Oil Lines" If you cannot work it out from there, then take it to someone that can because all of the work except the fittings and the Oil Cooler is DONE with that Kit! (Sorry, you will need a Bracket for the Oil Cooler also.
2 hotty
posted September 25, 2007 03:00 PM
cool......thanks guys for all of your help....like i said before i don't know much about zx-12's...thanks for all your help.....one other question....muzzy's, how do i get ahold of them?
posted September 25, 2007 11:50 PM        Edited By: entropy on 26 Sep 2007 00:52
call Muzzy in Oregon, they will send parts to you likkity split
1 541 385 0706 ext 106 (Dave Turner's extension)
When you get Dave on the phone tell him that Karl & Ryan said that you are a new member of Bikeland and qualify for the free bucket of chicken & biscuits!!
2 hotty
posted September 26, 2007 07:20 AM
cool thanks! i never turn down good chicken and bicuits!!!!
posted September 26, 2007 09:21 AM
Dave apparently looks like Colonel Saunders
when you call him, do mention some of us as we BS with him quite a lot; pretty funny guy.
(and quite helpful)
posted September 26, 2007 10:16 AM
Dave looks like Charlie Daniels but he can't fidddle
posted September 26, 2007 01:19 PM
Can't Play a Fiddle or cannot FIddle around!
DM, can you think of any better way than what I pointed him to? This is what I plan to use and do!
0.23371696472168 seconds processing time
