BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Boost advice needed NEW TOPIC NEW POLL POST REPLY
mrsantafe
posted September 07, 2007 09:26 AM
Boost advice needed
Who would you guys suggest to take on a turbo project and which kit?
My motor is a carpenter built bigbore, headwork, cams, falicon knifed edged rods, muzzy clutch basket, heavy duty shift shafts, ceramic tranny bearing, 5th and 6th gear od gears, 13.5 to 1, nos dry kit
I'll need a custom set of low compression pistons 8.0 to 8.5 to 1(where can i find them)
undercut transmission (billy robinson or R+D)
upgrade fuel pump(muzzys)
Heres the kits i found:
1. mrturbo
2. efir
3. superkaos?
4. Does Muzzy's still have a kit?
Any advice is greatly appreciated!
nox
PMRA / TMRC Super Street 4022
posted September 07, 2007 08:14 PM
I would go with Rnd On the tranny..........
Call Doug Ray about the turbo.........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
mrsantafe
posted September 07, 2007 09:05 PM
Sound advice as always thanks NOX.
posted September 08, 2007 07:28 AM
You can get some excellent components from Muzzy, if not a whole kit.
This one's all Muzzy....
posted September 08, 2007 07:34 AM
*drools*.....
TRNorBRN6001
I do believe Robinson made the 5th and 6th OD gears, he did a nice job on my trans as well. I almost wanted to put it on the mantle instead of in my bike. He also does a nice polish job and has low first gears as well for HeavyHitters!
On another note, I like Bear Racing's Plenum setup for the 12......................and I am sure Muzzy will still sell you a turbo kit for the right price. There are already a couple 12 turbos for sale on this site, psycho, and the Busa.org (motorhead) site as well. It just might be a little cheaper that way.
The Boost and your intended application will determine the compression and fuel needs.
I would assume it is for the street if your going to keep the big bore in it. For the street you may want to keep the compression up so it does not feel like such a turd in the lower RPM range, especially since you will not be putting too much boost on it with those thin cylinder walls. A spacer plate will work so you can save a little money on pistons.
7lbs of boost would sure be nice on a 175HP motor.
Just my two cents from an idiot though.
TFA 200MPH CLUB MEMBER!
0.4985339641571 seconds processing time
