BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Anybody ever change their thermostat...... NEW TOPIC NEW POLL POST REPLY
oldkawboy
posted September 05, 2007 07:13 PM
With the motor still in the frame?
Looks pretty tight & crowded in there and I'm trying to decide whether to just drop the motor out again for the swap unless it's easier than it looks in the frame.
Thanks,
Dan
posted September 05, 2007 10:09 PM
yep,
its not so bad. pull the TB's. not bad at all.
shiggsy
posted September 06, 2007 05:03 AM        Edited By: shiggsy on 6 Sep 2007 06:04
yep,
twice, once with the engine in, once with the engine out. I wouldn't drop the engine just to do the thermostat but if I was dropping the engine then I would definitely change the thremostat . Unfortunately one of the bolt heads for the thermostat block sheared off as I was undoing it, which they have a tendency to do, so if that happens you'll have to take the engine out.
I remember it as being a complete pig of a job with the engine in. I didn't remove the TB's (apart from letting in more light to see what your doing I can't see how that helps off the top of my head). Getting the fuel hoses out of the way is probably a good idea ,though I didn't do it at the time. Biggest problem I had was getting the thermostat to stay seated while you struggle to bolt the housing block back on. There maybe a technique but I ended up holding it in place with some silicon sealent.
(Replace the rubber o-ring as well, mine was well knackered).
posted September 06, 2007 05:13 AM
taking the TB's off takes 20min and makes the job a WHOLE LOT EASIER. Gives you room to get yr hands in there, and see what you are doing.
After I replaced thermostat, I tested the supposedly defective one on the stove in a pot of water & thermometer and it was fine... grrrrr
shiggsy
posted September 06, 2007 05:23 AM
Bet you didn't keep it as a spare though!
posted September 06, 2007 05:47 AM
bahahahahahahaha
you are right!
I smacked that lil bastid with a hammer for causing me so much grief.
ninja12
posted September 06, 2007 01:31 PM
Anyone find that the thermostat was actually the problem?
aliveagain
posted September 06, 2007 04:41 PM
I usually lower the motor with the bottom mounting bolt still in place.Radiator even stays attached to the front upper and pivots with the motor.Don't forget the muffler bolt.
oldkawboy
posted September 06, 2007 07:40 PM
Thanks guys for the tips, it sure helps out!
Dan
zx12mark
posted September 06, 2007 08:29 PM
my water pump went bad inside a year or so.i was looking at that thermostat and thinking thats gonna be a drag taking that out when its time.
0.28351187705994 seconds processing time
