liquidspice
posted September 03, 2007 08:30 PM
muzzy ultralight titanium full system...
hi,
ive bought a new exhaus system,since ive put it on,the bike doesnt work smuth when running idle.
and when i reach 6,000rpm,i feel a small choking.
what can i do to fix this? (what should i tune,add,replace)
how much effect does it have on my fuel consumption?
elad.
ZXLNT
posted September 04, 2007 02:03 AM
First thing would be to have a custom map made for it and go from there. Do you have a power commander? And as far as fuel consumption, if your worried about gas mileage you probably shouldn't be riding a 12R.
posted September 04, 2007 01:33 PM
Tony, he is over there where 1 MPG is worth adjusting a PC because $6 to $7 per gallon 1 MPG per tank is about $2 or 3 Saved
liquidspice
posted September 05, 2007 10:41 AM
quote: Tony, he is over there where 1 MPG is worth adjusting a PC because $6 to $7 per gallon 1 MPG per tank is about $2 or 3 Saved
liquidspice
posted September 05, 2007 10:43 AM
do you think p.comander will fix this?
quote: First thing would be to have a custom map made for it and go from there. Do you have a power commander? And as far as fuel consumption, if your worried about gas mileage you probably shouldn't be riding a 12R.
and will it improve my fuel consumption?
ZXLNT
posted September 06, 2007 01:36 AM
It might, even if it doesn't it will definately improve rideability..
madmike
posted September 06, 2007 08:10 AM
I sent you a PM...
posted September 06, 2007 08:15 AM
quote: It might, even if it doesn't it will definately improve rideability..
When Rideability is improved, you usually need less throttle for accel which takes less fuel. Even at wot, if your are now at 11 to 1 and remap to 13 to 1 you have saved a few gallons from being wasted. A well tuned bike uses less fuel than one out of tune
