BIKELAND > FORUMS > ZX12R ZONE.com > Thread: knocking? NEW TOPIC NEW POLL POST REPLY
brickman
posted August 23, 2007 07:56 PM
knocking?
got a 2000 12 that is making a knocking sound when in gear but if i pull in the clutch it stops. any one seen this be for? thanks.
posted August 23, 2007 09:46 PM
could be a whole ton of things...
check your oil first for "gold" if so you got a spun bearing...
then pull your pan and look at your tranny maybe have a damaged shift fork?
check the clutch basket make sure it is not broken or loose...
where is the knocking comign from?
How/When did it start after anything special happened?
brickman
posted August 23, 2007 10:36 PM
oil looked good it sounds like its coming from the tranny pulled the clutch every thing looks good. it only knocks when in gear and moving. but when i pull the clutch in it stops? the bike has been put up for about 4 years.i bought it new never had any problem.
woppi
posted August 23, 2007 11:45 PM
look at the chain ?
the front sprocket ?
shiggsy
posted August 24, 2007 12:01 AM        Edited By: shiggsy on 24 Aug 2007 01:01
I had what I would describe as more of a rattle than a knock, that came from the clutch area that went away when the clutch was pulled in. It was cracked clutch basket. (but it also did it in neutral).
ninja12
posted August 24, 2007 06:28 AM
clutch rattle is pretty common with heavy springs, not sure where it comes.
It sounds more like a big dry bearing than a knock.
brickman
posted August 24, 2007 11:34 AM
the bike is on a stand now chain off. it still knocks in gear. its fine in neutral?i am going to pull the clutch again and look at the basket.
brickman
posted August 24, 2007 07:42 PM
clutch basket looks fine. damn i hate to pull the pan. what should i look for? thanks for the help.
posted August 26, 2007 08:03 PM
tranny gear pcs...
or any metal at all...
did you pull your clutch fibers all the way out? You might have some broken fibers (longshot) but maybe causing your noise...
posted August 29, 2007 12:50 PM
Look for broken cushion springs in the basket itself. Make sure the drive gear anti backlash is working properly.
0.21951580047607 seconds processing time
