BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Lightweight battery information? NEW TOPIC NEW POLL POST REPLY
shiphteey
posted July 29, 2007 10:24 PM
Supposedly the ZX-12's battery is a whopping 8.1 pounds! Yikes! And I think it calls for about 200 cold cranking amps.
My question is what lightweight battery options could one look into? Obviously the big motor guys can not really go this route presumably.
I was looking at the YTX5...its about 3.5 pounds...only 70 cca though....would this be ok in the zx12 if I run it in warm temps only w/no lights drawing power from the system? We had one at the shop I wanted to try on my bike but it was just too dead to even take a charge.
I'd like something pretty light and has been actually tested by other 12 guys on here...
About how many cold cranking amps does one need to fire up the 12 in warmer climates? Is there a minimum one should aim for so as to not hurt the charging system? Last think I'd want is a weaker bike while trying to make it lighter, lol!
A.
TRNorBRN6001
posted July 30, 2007 12:35 PM
Mad Mike is the man to talk too, he is the battery master!
TFA 200MPH CLUB MEMBER!
nox
PMRA / TMRC Super Street 4022
posted July 30, 2007 07:39 PM
If it dont start, it cant go fast...............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
stef12rr
posted August 07, 2007 07:07 PM
IH i did not weight the zx 12 batterie but i think is about 11pound for a 14amp
THE ICE MAN
posted August 10, 2007 06:53 PM
Your light enough
ACE PERFORMANCE.COM
40 Records@ Maxton, Fastest NA
1507cc Busa 223.330 MPH also
Fastest ZX12 N.A.212.846 MPH in
the mile Fastest 1000 750 @ Maxton
& Fastest 600 N.A. in the world.
H2 to ZX12
two stroke power
posted August 12, 2007 04:21 AM
take the tire off, you'll save 12 lbs. you don't need 'em in the sand
  Ignore this member    Click here to visit H2 to ZX12's homepage.
posted August 23, 2007 10:05 PM
Hey dude why dont I build you a NiCad or Ni-MH pack??? I can give you what ever you need voltage wise and if we use RC cells no problems with starting and they can handle a 30A draw with out any problems... only issue is the cost, but I can help you a little there...
so if your interested give me a shout on my cell...
MM
we can do a 3300mAH battery very easily and it will weigh in about 1-1.5lbs... I have done some for a few Dragbikes...
shane661
posted August 24, 2007 03:59 AM
Would that setup be streetable at all?
madmike
posted August 24, 2007 07:34 AM
No but it would be pretty easy to set up a system that you could pull your stock battery for LS and just plug in this one...
0.21786117553711 seconds processing time
