BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Bike smokes, looking for pro's NEW TOPIC NEW POLL POST REPLY
SVTFord94
The Man... Period...
posted August 21, 2007 11:35 AM
Whats up everyone im new to the forum my names mike, friends call me bigmike, i own a 03 green zx12r couple mods such as full custom two brothers titanium system, with k&n air filters, muzzy block off plates, which i recently took of and put the air injection back on,problem is i get a puff of blueish black smoke when i wack the throttle and i cant figure out what is going on? if someone could enlighten me on to whats going on with my bike or maybe this has happend to them please let me know thanks! BigMike
BigMike
  Ignore this member    Click here to visit SVTFord94's homepage.
capt10ed
posted August 21, 2007 02:43 PM
Try to give more detailed information. Did you switch back to the air injection because it is smoking? Did you just aquire the bike? What kind of milage ? Was a fuel map recently done? etc.
and 204.5 in the mile.
svtford94
posted August 21, 2007 03:37 PM
i had originally bought the machine from a older gentleman with 6300 on the clock last year, put the exhaust, power commander, air filters, blockoff plates on during the winter then had it dyno tuned by a repitable shop, smoked at WOT ever since then and stinks like oil. Bike has 19k on the clock now but has been meticously maintained oil changed every 1200 miles etc. and never smoked previosly to putting mods on, so i figured it was the air injection cause i heard of people having problems with the bike smoking on decel, didnt fix it although it does run alot better now that i put it back on, please let me know if u need to know any more
BigMike
Texas12R
posted August 21, 2007 03:39 PM        Edited By: Texas12R on 21 Aug 2007 16:42
Compression test? Better yet Leak down test?
Check oil level at the window to be at the center?
Im probably wrong .....at least I hope I am
Rich tends to be black.....
oil slipping by is blue and lingers
Oh IM sorry......Im NO pro!!! by any stretch of the imagination
svtford94
posted August 21, 2007 03:41 PM
was planning on a leakdown, yes oil has got to be getting by somwhere, changed oil every 1200 miles with exactly 3 quarts each time.
BigMike
tcchin
posted August 21, 2007 06:35 PM
What have you done with the crankcase ventilation system? If you aren't sufficiently venting the crankcase, you can experience problems similar to the ones you have. You can also oil-starve the motor if the crankcase pressure gets too high.
kawasabi
posted August 22, 2007 05:17 AM
Question, can the crankcase pressure get to high if the CV system is left in the stock location to the airbox (frame)? I am guessing that the reason why some of us see oil leaks (can sensor, valve cover, the dreaded stator connector) is becuase of this. Crankcase pressure builds because of blowby and the pressure in the airbox is adding to that when ram air is in full effect.
psycho1122
posted August 22, 2007 05:27 AM
Check for oil in the airbox due to the crankcase breather vent point.
The Clean air valve body contains a foam "Oil Absorber". I would take it off, dis-assemble and clean with a low flash point solvent. Also, pull the vavle cover and check and service the reed valves.
At this point, you should pull the plugs, inspect or replace and do the compression check.
Y2KZX12R
CompetitionCNC.com
posted August 23, 2007 03:14 AM
More than likely you are drawing oil into the exhaust ports thru the air injection ports from around the seals under the valve cover.
Its a very common problem but an easy fix.
Remove the valve cover and clean the air feed tubes in the head. Twist some small cloth rags and stick them in there about an inch or so and do it several times with a solvent on the rag. Once you have cleaned out those passages so there is no residue on the rag any more, inject silicone sealer in the tubes and fill about an inch worth of the tube untill its flush with the top of the tube.
Wait 24 hours before starting it.
Y2KZX12R
CompetitionCNC.com
svtford94
posted August 23, 2007 09:14 AM
i was planning on replacing the plugs, so this would prob be a good time to check these issues thanks for all your info guys, very much appreciated!
BigMike
posted August 23, 2007 10:35 AM
Mis - plumbed KLEEN System.
svtford94
posted August 23, 2007 10:53 AM
Doug, i dont think i have it plumbed wrong, i got the vacumm hose from the throttle bodys going into the slot for the tube on the front of that canister and that bigger hose going to the air box, i dont think i have it mixed up, it was smoking like this when i had the block off plates on also.
BigMike
posted August 23, 2007 03:22 PM
I don't quite get that. But then I don't have it in front of me to look at.
Where is the case vent going?
svtford94
posted August 24, 2007 06:36 AM
case vent is all stock i havent touched it, only thing i did do was take off the kleen air system, pluged the vacumm line from the throttle bodies and plug the bottom of the air box where that existing hole was from the kleen air canister hose, and put those plates on, started smoking at WOT and decel, so i put the system back on the way it came off, havent touched the CC vents or anything like that, i did notice it ran better after i put the system back on, but oil is still getting by somewhere i wack it i get smoke and when i let off i get a puff of lingering blueish smoke, so its obviosly oil, just cant figure out where its coming from, friggen exhaust stinks to.
BigMike
BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Bike smokes, looking for pro\'s NEW TOPIC NEW POLL POST REPLY
0.2405378818512 seconds processing time
