shiphteey
posted April 05, 2007 06:58 PM
Edited By: shiphteey on 5 Apr 2007 20:00
Shiphteey's rebuild and tune-up March 07
Well, my transmission was starting to go out (gears 3 and 4) which I only seemed to notice under HARD acceleration (maxton and finally 9/10). Honestly I was pretty pissed losing an n/a run against Deezuh's 10 knowing that it was my transmission that was at fault! Figured transmission issues NEVER get better :lol: so I decided to have it sent out and done right by R&D 8)
I figured while I was at it, why not throw in stiffer valve springs since I like revving it high and use nitrous? So threw in some valve springs (YES I got some tips from ACE PERFORMANCE, NO I CAN NOT TELL YOU!) :lol: and fresh valve seals to go along with it.
Upon disassembing my motor and related hoses/connectors, etc we ran into a slight corrosion problem, mainly attributed to Bonneville:
Cams look good
Bottom end looks good
But something catches Rick's eye! He said the cam chain is SHOT (KINKED would be an UNDERSTATEMENT!) but if I REALLY wanted to use it for Texas I could :?
It was so messed you could have had the chain sitting up and it would still stay in its kinked up form!!! :shock:
(On a side note I felt good about my 202.9 mph run @ Maxton in October now! :lol: )
Well, with 2 days to go I had no choice but to order from Cali overnight since no one on the east coast had a cam chain!
New cam chain goes in
set up properly by Rick Beggs
Rick putting on the finishing touches
Cleaning, lubing and reseating the Bear stacks
It took 8 friggin hours to finally get these wheels set-up. Blais Cycles sent the incorrect spacers, the shop I ordered an entire set from sent the wrong ones, but we ended up trial and erroring with non-stop measuring, rechecking wheel allignment up until 3am Thurday before TX MILE! Finally within 1mm to spec!
Zoe during open heart surgery only days before I left for TX (actually THE day before :shock: )
Got it all done by the skin of my teeth....an extra special thanks to Rick Beggs of RnR Cycles for getting it done that quickly AND with that much attention to detail! 8) He is the man!
I am hoping with the newer cam chain, fresh chain, ceramic bearings and carbon wheels will yield me enough to break 205 mph @ Maxton. Should be a LITTLE more but I'm conservative (like my nos mapping :roll: ) Forgot to mention Rick installed my lowered forks and set the ride height JUST RIGHT to cure my stability issues!
See you guys in May! :twisted:
A.
posted April 05, 2007 09:47 PM
hey, Ali, cool pix!
Do yourself a favor and shitcan that manual cam tensioner, it eats cam chains and slippers.
Bad ju-ju.
hyper12r
posted April 06, 2007 08:06 AM
muzzy cam spocket,advancer?
osti33
posted April 06, 2007 09:41 AM
Edited By: osti33 on 6 Apr 2007 10:42
Bad ju-ju.
+1 Cool pics.
But I agree with Karl on the tensioner. The stocker works just fine.
shiphteey
posted April 06, 2007 01:53 PM
So how long do the stockers last? Mine crapped out after a 180ish mph roll-on (sounded like a diesel...parked it, had a buddy come pick me up because I thought I did much more damage to it). I think I only had 6k or so on the motor?
A.
shane661
posted April 06, 2007 02:18 PM
Edited By: shane661 on 6 Apr 2007 15:18
quote: So how long do the stockers last? Mine crapped out after a 180ish mph roll-on (sounded like a diesel...parked it, had a buddy come pick me up because I thought I did much more damage to it). I think I only had 6k or so on the motor?
A.
I really doubt that was the cam chain tensioner, my friend. More like an electrical gremlin or something. I recall that Slow Lane was even fuzzy on the cause...it was intermittent.
Mine has 20k on it, and you know how it just ran with Cronan on it, plus 125 drag passes with my fat ass on it.
harryzx-12
posted April 07, 2007 06:15 PM
Good pics Ali. I hope to see you in may.
rac4it
Bergie
posted May 01, 2007 06:31 PM
Ditto on the manual cam chain tensioner. Get rid of it, does more harm than good on a 12 if you're not very skilled in keeping properly set.
shiphteey
posted May 02, 2007 10:24 AM
Edited By: shiphteey on 2 May 2007 11:31
Haha, another little shot from Bergie, nothing new....keep sipping the haterade.
BROOKLYNNYZX12
posted May 03, 2007 07:08 AM
If Entropy told me to shit can the manual tensioner and Osti and Bergie tell you the same thing,I would listen.Read all the horror stories about the manual tensioners.It's obvious that valve trains need some flex.Don't find out the hard way.Jus my .02
Orient Express Top Street Bike Winner 8-4-07
shiphteey
posted May 03, 2007 07:53 AM
I understand what you're saying, don't get me wrong. The reason I spit that is because Bergie jumped on Bikeland May 01 and posted, specifically singling out MY posts to reply to (diss). Check out the other 2 and you'll see what I mean.
A.
countersteer
Didn't read the owners manual
posted May 03, 2007 09:30 AM
very cool stuff
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
Megabyte
posted May 03, 2007 11:35 AM
Wow, your pictures are so cool I want to tear my engine down
posted May 03, 2007 03:46 PM
If it matters, I agree. The stock tensioner is the way to go.
Doug
Megabyte
posted May 04, 2007 10:57 AM
quote: If it matters, I agree. The stock tensioner is the way to go.
Doug
I've resisted putting my stocker back on until now. I do respect the experts on this board, and I respect the expert and team that helped build my 212 rwhp stroker. When this work was done, there were reports of failures with the stock tensioner on stroked bikes, and the decision to go with a manual tensioner wasn't made in a vacuum. I could name names, but what good would that do. Anyway, thanks for the expert advise. It's been heeded.
crashtech
posted May 05, 2007 04:44 AM
cam chain tensioner
quote: Ditto on the manual cam chain tensioner. Get rid of it, does more harm than good on a 12 if you're not very skilled in keeping properly set.
+1 on key phrase keeping properly set. Seen more stockers fail then manual ones.
posted May 05, 2007 06:38 AM
the manuals NEVER fail. They just eat cam chains, & slipper guides.
I agree 100% with crashtech, keeping properly set is the key phrase, yes indeed.
IMO I haven't YET seen the person who has that process down perfect.
NO benefit to Manuals...
crash:
Offtopic
paint
how much would would it cost for enough Y2K green paint to paint the cop car i'm getting in July???? I want it to match my bike. doesn't have to be a pristene paint job but the color has to match.
crashtech
posted May 05, 2007 12:05 PM
One benefit.....the oem one wont malfunction...lol
On the paint thing, I have the color in a 2-stage that I developed myself. It is much cheaper then the oem 3-stage. It is close really, but not dead on. Great for blending and panel breaks in color. The 2-stage is still a little high because of all the zahrilick pearle in the formula. You could paint a cop car with about 2 quarts or litres of color. then you need clear. The color will run you about 175-250 a quart depending on your local taxes (haz-mat, epa, ect.) are. Clear and hardener are about 100-200 for a gallon for both.
posted May 06, 2007 03:42 AM
CT,
Thanks for the paint info! So $800 for paint, eh???
That's within my TFA budget!
Karl
crashtech
posted May 06, 2007 04:49 AM
Yea I know, it blows. The cost of paint now days. Let me get into work tomm. and I will work the numbers. I am thinking about 550-650. Thats why nice paint jobs are at least 1000 and up, Materials. I might be able to convert the formula over to our bottom end line of products (whole set-up for 250-350) but you get what you pay for.
posted May 06, 2007 06:19 AM
Edited By: entropy on 6 May 2007 07:20
my plan is to get 4500 cop car, and have it painted the same color as my bike. July/August timeframe.
my wife isn't quite as enthusiastic as i am about the project
thanks for yer help!
Megabyte
posted May 07, 2007 09:20 AM
Cam Adjuster Instructions
http://www.dansmc.com/camchain_adjust.htm
Article claims most Motorcycle engines from 1980 on use a manual adjuster ?? Otherwise, I thought the instructions were helpful, but would appreciate a more knowledgeable opinion or tips.
Thanks,
posted May 07, 2007 10:07 AM
Thanks,
Mega,
"Most of the newer engines (say from the early 1980s on, give or take) have the non adjustable type of Cam Chain tensioner. You simply install it and it works. When the chain get noisy you put a new Cam Chain on. Not much else you can do"
I think they are refering the OEM type on the 12 (as opposed to the manual adj).
Megabyte
posted May 07, 2007 10:45 AM
Thanks,
Mega,
Yes, that makes sense. non adjustable means you don't have to adjust it, as opposed to a manual one duh
rac4it
Bergie
posted May 10, 2007 01:14 PM
I'm trying to help you not bash you..
WTF
