shiphteey
posted April 19, 2007 11:51 AM
Gained 2 mph w/the help of ACE PERFORMANCE bearings!
Well, ran at the 1/8 mile strip last night. Todd rode his 1k and Shane rode his 12.
Anyways, whenever I run n/a, if there are no big wheelies or tons of wheelspin I run 118 thru the traps, whether its 18/44 gearing or 17/46.
Well, with the carbon fiber wheels, lighter titanium muzzy headers (vs stainless muzzy) and front and rear ceramic bearings from ACE I picked up 2 mph thru the traps!
I did it at least 2 times, maybe 3, I have to go back home and look thru my slips again.
This is inline with ICEMAN's findings when swapping from stock to ceramic at the 9/10 (7/10 mile run).
As a comparision, last year I would sometimes spray 2nd gear and whatever bit of 3rd before the trap and get 120! That is a 40 shot dry from the 80ish mph mark to 120.
My honest feeling is that the ceramic bearings DO make a difference!
Look for a follow-up report when I get back from Maxton this may!
I will run the same set-up as always, stock rev limiter, same tires, fairings, gearing, etc. Best was 202.91 so far....
Hoping the lighter wheels and ceramic bearing will get me 205+!!!!!!!! I have run them at TX and Maxton in March but TX had headwinds and Maxton was naked so I couldn't "compare" them. But as a reference, I can say I went faster than all the other Kawasakis at TX (tied the turbo 14 with a 194)....Entropy's 1427 went 193, Ryan's 1394 nos was not too far behind either! Don't think I could have pulled that off w/out the wheels and bearings to maximize my weight advantage and reduce frictional losses given the HP I was giving up to those guys!
A.
osti33
posted April 19, 2007 04:41 PM
Good deal. Glad they helped you out.
I've thought about buying some but I could never justify spending the money.
posted April 20, 2007 03:15 AM
Invalid test if you made more than one change between baseline and test run. If you did make all those changes, the wheel weight change is far more significant than the bearing material, which is virtually insignificant.
posted April 20, 2007 05:49 AM
quote: Invalid test if you made more than one change between baseline and test run. If you did make all those changes, the wheel weight change is far more significant than the bearing material, which is virtually insignificant.
Like my Mom says: "great minds run in the same gutter"
(from a reply I made to Ali on SH.org)
"Ali,
I would put much more of yr gain on the wheels than the bearings, but just my opinion..."
shiphteey
posted April 20, 2007 06:05 AM
Edited By: shiphteey on 20 Apr 2007 07:17
Doug, maybe you missed the title of this post, please read again very carefully:
"WITH THE HELP OF"
Yes, I had lighter wheels on so that is a significant portion of the gain. When I run Maxton I will post the results up: Lighter wheels and ceramic bearings.
How is it invalid to say that I gained 2 mph and list the changes I made?
Let me guess....if I gain 2 mph at Maxton with those wheels and bearings you'll be the first to say its just the wheels even though both Iceman and Guy Caputo have seen about 2 mph difference just by going to ceramics....? Yes, I realize HOW MUCH LIGHTER my wheels are than stock, I have weighed them myself and know how much weight savings from rotational mass translates to in forward motion! But to dismiss the ceramic bearings altogether when there are people who routinely go well over 200 mph and have similar claims is FOOLISH.
Whats next, you gonna tell us 200+ is possible on a stock geared, stock tired, stock rev limiter zx12 again?
A.
Megabyte
posted April 20, 2007 12:02 PM
A.
Years ago, I read a post by somebody @ Muzzys claiming that the 1361 didn't generate more heat just going down the road, when I knew my 1361 had heating/cooling issues it never had when stock. However, i didn't presume to accuse this person of being a liar. As it turns out, my 1361 doesn't really run that much hotter under normal driving, it's just a lot harder to start when it's warn/hot because of the higher compression, etc. If I were you, I'd give Doug the benefit of the doubt; he's earned it.
Y2KZX12R
CompetitionCNC.com
posted April 20, 2007 02:40 PM
I'd put money on it that the change in wheel mass is where 99.99% of the gains you saw came from.
On a dyno you will see a handfull of hp gain from a lighter weight rear wheel. And on the road the front comes into play also.
You may also notice a braking performance increase from those wheels.
Y2KZX12R
CompetitionCNC.com
shiphteey
posted April 20, 2007 04:06 PM
How much money would you like to put? For the right price I could justify swapping out the ceramics back to regular and run:
stock wheels and bearings
carbon wheels and regular bearings
carbon wheels and ceramic bearings
The 9/10 this fall would be the perfect venue because I don't have to sit around all day to make a pass.....
What are you asserting? That I will see no difference with carbon wheels/regular bearing vs carbon wheels and ceramics?
Again if you're saying no difference and you're willing to put money on it, for the right price I'll do it, hell I'll split the earnings w/some of the 9/10 guys that I may need to help give me a hand and swap wheels quickly to help isolate variables like wind/temp changes.
A.
shane661
posted April 20, 2007 04:08 PM
Edited By: shane661 on 20 Apr 2007 17:09
I will assert that your gain in the 1/8th would be smaller than your penis...meaning microscopic. Top end yes, 1/8th....hardly measurable compared to lower bike, step seat, new trans, carbon wheels and freshened top end, different gearing....etc..
shiphteey
posted April 20, 2007 04:17 PM
Yoohoo! Knock knock....anyone home shane?
Must I post all my slips from last year or do you know that they were all high 117s, predominantly 118s no matter WHAT gearing! You don't gain MPH from the gearings, you gain ET!! WAKE-UP BUDDY!
Freshened up top end? You mean stiffer valve springs which rob HP?
How does my set up with a lower seat and lower bike add MPH Shane? I'm all ears!
Again, how does the transmission add MPH? Is this the part where you lecture us about how a heavier flywheel is better?
Hey, the title of the post says WITH THE HELP OF! And I think they helped!
We will see how the wheels and bearings helped. Sure my pipe was lighter than before (stainless vs titanium headers & midpipe) but I ran 1-2 more gallons of gas that night too! So what?
I smell a little hate.....but I guess I could see why you're hating....given that I ran 6.9 on your bike spinning the tire thru gears 2-4.
A.
shane661
posted April 20, 2007 04:23 PM
Edited By: shane661 on 20 Apr 2007 17:33
New valve seals added, correct? Adjusted valves, correct? Quicker shifting trans, correct? Lighter wheels, correct? Better launch with lower CG, correct? Lower overall gearing, correct? Step seat is lighter, correct? New rear tire, correct? More experience, correct?
I think the heavier flywheel is better...you turned a 1.75 60 ft. first time on my bike...with little drama. Imagine what you could do with more seat time. And my bike sits a lot higher than yours.
As for the 6.9...my only regret is that it spun on you. I wanted to see what the bike was capable of.
It's not hate...let's keep it real, and not make every post a billboard advertisement.
Oh...if you add lower (and better suited) gearing, but can get wfo faster due to setup...I will assert that there will be a mph gain.
No question that you are skilled and fast....but I think that in the 1/8th ceramics are not the primary, or secondary cause of your gains....
posted April 20, 2007 06:29 PM
Edited By: dougmeyer on 20 Apr 2007 19:33
My point is that you simply do not know where the change came from. You are only making an assumption. NO evidence whatsoever. You made several changes to your bike. It went faster. Is there a link? Maybe, maybe not. The only way to tell is to baseline, make a change, return to baseline. If the changes yield the result and the result goes away when you return to baseline you have evidence. If you made more than one change you still don't know what caused thye result; the change of one, the other, both collectively or some specific combination of of the items.
How does your lower seat and lowered front end effect your times? By reducing frontal area. (More of your tires are masked by the bodywork.) I could see a measurable change here depending on how much you lowered it. Also, you changed the weight distribution and centers of pressure, both of which will effect your times and top speed.
Example: Move the center of pressure rearward and the front of the bike rises with increasing speed, increasing drag (significant) by unmasking the tire and changing the shape.
Oh, thanks, Mega...
shiphteey
posted April 20, 2007 11:20 PM
Edited By: shiphteey on 21 Apr 2007 00:22
In no particular order...
Mega: I respect DM, and if he doesn't or didn't know it even though I have stated it before he does now. That doesn't mean he is infallible and shouldn't be questioned! He is a human like the rest of us and bleeds red (ok green). I have had differences of opinions with him on a few things (like shooting nitrous ONLY is called a dry system, whereas he asserts bumping up the fuel in the power commander makes it de facto wet). Anyways, you get the idea.
Shane: Spare me man. You have been with me at the strip. You out of all people know what MPH I run whether its 6.3 or 6.5: 118 mph. And thats with 17/46 gearing or as tall as 18/44! You KNOW that! Adding MPH like that is more a function of freeing up ponies, adding hp, or even aero mods as DM has pointed out. Just getting on it WFO a hair earlier doesn't add
2 mph
Shane.....if you think it does, if you think you can just ADD that kind of mph up top from gearing changes and going WOT earlier then I don't know what to say honestly! How exactly can you go WOT earlier with 17/45 gearing than 18/44? I'm all ears on this! And don't hate because I'm thanking Sal for the bearings....if someone has helped go faster along the way and I think it worked why wouldn't I mention them?
DM: Again, the title of my thread said "...w/the help of ..." did it not? Simply put, they helped, so there isn't really much to dispute here. Now you are correct of course in that the only way to tell HOW MUCH is to isolate ALL THE VARIABLES, something I didn't have time nor desire to do merely for the sake of science (at least this time around). My overall ride height was "about" the same. Why? The rear didn't change but the front has lower forks (2.5") but now the forks are at the top and not slid 1" thru the triple. Now I have a 120/70 tire, not the 120/60. AND I usually run at the strip with a strap, this time I DID NOT! Frontal aera would be minimally changed IMO. The drag seat doesn't get me that much lower from strictly an aero point of view (went over this before Maxton to see what the gains would be with my short ass). My chin is still on the gas cap in aero-tuck mode. At the strip I don't scoot that far back because its more beneficial to obviously be as low and FORWARD as possible. Problem I encounted with the step seat is that with in jeans I would still slide back a couple inches till my tailbone hit the 1st step....right around torque peak 9k rpms or so in 1st....and up she would come wheelying till I backed off a hair. Happened most of the runs and Shane/Todd can vouch for that since I was in front of them when it would happen. And while I see where you're going with the centers of pressure, I think that is a little overkill for 1/8 mile MPH analysis considering the other more significant variables:
Wheel weight
Lighter pipe
Lower Drag ceramic bearings
I have no regrets about buying them, as you know in top end racing any time you can reduce some weight, add some hp, reduce aero drag, or reduce frictional losses its probably a good idea.
A.
posted April 21, 2007 02:44 AM
OK That all makes sense. But you didn't say all that. Your original post was a statement that you now had proof that "Ceramic bearings DO make a difference." Which, I felt, was bit of a stretch.
Just to be clear, I've never said they were a bad thing or did not contribute in some minute way to performance. My point has always been that you are not going to find attributeable increases in speed or decreases in ET with this change alone (assuming the stock bearings were undamaged).
Pressure and drag - Sure it is, but you're the one that figured in the seat and ride height and asked why it mattered.
Whatever, I'm just glad you're out there tryin'!
Doug
rac4it
Bergie
posted May 01, 2007 06:23 PM
Ship did you ever attend a science class? Your testing is complete assumption and has no real data.
narider
posted May 02, 2007 03:19 AM
Bergie, he may not be scientific about it, he may assume some things and he may not have any spec'd or detailed data logged. But Ali does have something most others don't.... he's out there and doing it in any and every venue he can.
He's not talking about what he's not doing on a regular basis... including track days, 1/8th mile, 1/4 mile, 9/10th's, Texas, Maxton and Bonneville. He will put it on the line with anything in his sight and not have an attitude about it win or lose... a pretty rare quality in many today.
He may talk a lot of shit to get people riled up, but it's all in good spirit and he puts his tire to the ground more then he puts his mouth to the internet(hard to believe sometimes - lol). He'll share everything he knows about himself, his bike and anything he thinks might help anyone around him(competition or not). Again, he's there and doing it(no matter where "there" is).
Ali's one of the most stand up guys(and I know a couple) that I've ever met, and I'm glad to see his level of involvement in the industry for many involved... including my wife and myself both.
When you coming back to the track to gain, collate and share your data by the way? Been at least couple years hasn't it?
Todd
posted May 02, 2007 04:14 AM
Edited By: entropy on 2 May 2007 05:15
quote: ... [Ali] puts his tire to the ground more then he puts his mouth to the internet...
BAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA :BIGTHUMB
that is funny as hell!!! VERY well said.
Todd,
I agree with you 100%; Ali IS a standup guy who is gettin after it!
Yep he can be a "chatty Kathy" on the internet, stirring the pot & whatnot, but he's a real nice guy in person.
We enjoyed having him show up in Texas at the Mile, yes indeed.
shiphteey
posted May 02, 2007 09:24 AM
Edited By: shiphteey on 2 May 2007 12:15
----Bergie, I know you're not talking. Do you really think YOU out of all people have ANY room to diss? Considering you are PUBLICLY known as a
CHEATER
(over the displacement limit running a stroker motor in the 1350cc class)
Read the title of the post one more time....WITH THE HELP OF! Are you getting it? Clear enough for you? Jeez ... some people are just full of haterade. You've been like that w/me since day one when I ran at Maxton, dissing my MPH and my efforts.
And to think, you ran your mouth about running naked and suggested not even running the ram air tubes....either you're trying to give out bad advice or you're THAT CLUELESS about how much HP the 12 makes with ram air once underway. Then again, with an
ILLEGAL STROKER MOTOR
you don't have to rev it up as high and aren't dependent on all the little things to go right like I am.
I'm done here. If you even want to open your mouth, why not FIRST tell us exactly what your displacement was when you ran got into the 200 mph club illegitimately? Come on Bergie, you talk so much, and every time ANYONE has checked you on it you NEVER REPLY. Tell us why you took off your displacement from your home page years ago when someone asked how you were able to run that displacement in the 1350 class when it was OVER the limit? I remember that post where you were talking about how Lee set it up back to stock bore but stroked it still to remain legal? Gimme a break...that means you kept swapping back and forth between running at Maxton (to be legal) and then going to your 1361 set-up? BS. How many times did you do that?
And weren't you the same guy who got his ass BUSTED at the street races by the bridge by a zx9 OVER AND OVER AND OVER!?!? Hmmm?
Weren't you the same guy that looped his 12 at the strip and broke both of your legs?
As far as science class, I mentioned the changes I made to the bike and the MPH gained and I believe to some degree the bearings did help. Rolling it around the parking lot it rolls a lot easier than before. Multiple changes HAVE been made so I can't prove causation but I can imply corollation.
Have you ever taken a Philosophy Ethics class?
Now fuck off cheater.
A.
NOS1290
posted May 02, 2007 09:56 AM
One of the reasons why there are so few posts on this site in recent months is the quality of the information has quite honestly gone down with the quantity of the BS. Doug and others try hard to offer information for all of us out here trying to learn a thing (or share a thing) or two, but you end up wading through kindergarten rantings (see post above) to get there. Perhaps people would be more engaged if the hostility was toned down. Other groups I participate in have 100+ posts per day. Sad thing is the offenders don't even know who they are... BTW, making fun of someone getting hurt is despicable.
shiphteey
posted May 02, 2007 10:22 AM
Well well well, look who decides to post up. The guy who is still irrate about me accidentally leaving his tools out after my first nos pass at Maxton and making a huge blunder. I have offered time and again to make things good with you, you know that. Instead you'd rather hold onto your bitterness and take a shot here and there. What a suprise bro. I ripped into Bergie because I can't tell you how many times he's taken shots at me, stupid little snide remarks all the time.
Looks like you are still bitter even though I have tried to make amends w/you. Hey, you want to keep holding on to your bitterness, fine by me. But try looking at the BIG PICTURE next time.
And who made fun of Bergie breaking his legs!?!? I was pointing out that he's not the baddest drag racer out there! That he is human, that he isn't flawless, that he makes mistakes just like the rest of us. And that he should look in the mirror before dissing others. Looks like you are only picking and choosing what you want to respond to and attempting to diminish my character. A for effort.
A.
rac4it
Bergie
posted May 10, 2007 01:18 PM
Bring your displacement tools to Maxton Ali and check my bike, PLEASE.
rac4it
Bergie
posted May 10, 2007 01:30 PM
Get your facts straight and stop running off your mouth before it gets you in real trouble.
-My bike is legal.
-Nope, never broke my legs. Never looped my bike. I broke my wrist and my ankle after setting down a wheelie in 4th gear @ 120mph, tankslapper, no damper.
-No, I've never lost a street race especially not to a ZX9. Sorry you must have me mistaken with someone else. If you're talking about that alcholic Joe in Chantilly VA, he backed out of a money race after running his mouth for weeks, then when I ran him just for fun he lost by about 15 bikes and said "I thought you would have been further ahead" then lied to his friends about it. I have a handful of witnesses.
I was running 9.50s on a stock wheelbase ZX12 six years ago dude. Seriously show me something, anything you've done, without nitrous.
All you do is run your little mouth. YOU are known for calling people cheats when you can't imagine doing what they've already done. Didn't you call Doug Meyer a liar about going 199 on a stock motor? Hmmm I see a pattern!
I have only tried to help you but your ego is too big to listen.
Obviously I'm wasting my time. I'll share no more with you, learn it the hard way.
shane661
posted May 10, 2007 02:29 PM
quote: Get your facts straight and stop running off your mouth before it gets you in real trouble.
-My bike is legal.
Hey man. I don't know you, but I have just a straight question. How many cc's were you running, and with what bore and stroke did you make those records at Maxton?
I hate when people talk shit without proof, so I'd just like to know the straight scoop. You can PM me if you want...
