BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Stator Re-Winding NEW TOPIC NEW POLL POST REPLY
zxlnt
posted May 23, 2002 02:13 PM
Stator Re-Winding
The stator on my 01 12R I bought wrecked is damaged. It has a few winding on 4 different coils that are ground on. In a couple places the wires are shorted to each other and almost ground halfway through. Anyone know of a good reputable stator repair shop? I haven't had much luck here locally. I did find one or two places on the internet that can do it. One looks like it be around 165 dollars or so for the 18 coil Kawasaki stator. That sounds like a damn good price to me considering a new stator is more than twice that.
slug
Out in search of my mind...
posted May 23, 2002 04:21 PM
find out what size (guage) wire it is and rewind it yourself.
determine the winding pattern, look closely at how it was done. unwind the old, count turns, and note where the crossovers are. also note which spot on core it comes to.
and if worse comes to worse, if you still can't get it to work, then you aren't in any worse condition than when you started.
165 dollars for maybe 20 dollars of wire (at radio shack retail price) and a bit of time.
the key though is when you unwind it to take GOOD notes.
make a form the same size as the coil you need, and wind around that.
;P
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
zxlnt
posted May 23, 2002 04:28 PM
;P
Gimme your address and I'll send it off to ya with 20 dollars worth of radio shack wire I thought about re-winding it myself. I hav neither the time nor the patience for that.
0.2929949760437 seconds processing time
