BIKELAND > FORUMS > ZX12R ZONE.com > Thread: KISS (I will be going to Maxton and Go Fast Finally!) NEW TOPIC NEW POLL POST REPLY
posted September 15, 2006 09:32 AM        Edited By: VincentHill on 15 Sep 2006 10:32
We all know that I had some kind of problem for over a year with I NOS! Well today I resolved it 100%.
I was up to Very large NOS Jets (#42) and still no power!. A #42 should make about 300HP. I did some serious flow testing and found that no matter what I did I could not flow more than .5 to .6 Pounds of NOS in 10 seconds. It takes .8 pounds to make 100 HP so I needed at least 1.2 pounds at the Pressure I want to use. I know the last SOlenoid was Junk and leaked but it was not the entire problem. So I hooked up the line to the Solenoids and nothing on the other side and still no more than .5 to .6 pounds of NOS.
I called NX again and Mike SUggested that I get a 1/4 Ball Valve to see if the Solenoids were the problem. He even stated that if it was, that he would send me the latest for free. He said that "Everyone" there knew me by name by now and all wanted to help me!.
WHile having my 2 10 Pound Bottles filled I did the testing with a 5 pound bottle. I had everything hooked up and only .5 pounds with no restriction going through #39 Jets. I then decided to bypass the line but did not have the Adapters so I used another line 2 feet long.
I almost lost control of the set up! It flowed "2 Pounds" in 10 seconds SOn of a Gun, the 3 foot AN-4 line was bad and getting worse the entire time. I hope everyone can learn something here! Keep an eye on your NOS Lines when you have a flow problem!
Now to slow the flow down I am not going to try to use a 250 SHOT (Yet)
Keep It Simple Stupid
harryzx-12
posted September 15, 2006 10:51 AM
I'll se ya there vincent. I'm going to try to get as many qualifying passes as i can on my zx-12. I'm hoping to go over 175 to get my "B" license. When are you getting there? Do they allow you to camp there?
posted September 15, 2006 11:13 AM
Yes you can camp there no problem and great people. I get in Friday evening late and go directly to the Hotel to SLEEP!
BROOKLYNNYZX12
posted September 15, 2006 11:40 AM
Some AN lines deteriorate on the inside,on cars you are supposed to use a special AN line for transmission cooler lines to avoid a restriction problem like the one you had Vince,hopefully it will be all sorted by the time you get there.Good Luck!
TRNorBRN6001
posted September 15, 2006 11:45 AM        Edited By: TRNorBRN6001 on 15 Sep 2006 12:47
Bad line, that's rough! Can't wait to hear you ran strong Mr. Hill. Keep us up to date, is your son going with you this time? Hope the weather holds and the track is smooth with no cones in your way. If everything goes well you might be the fastest 12 out there!
TFA 200MPH CLUB MEMBER!
wannabe
posted September 15, 2006 11:55 AM
Good luck, Vincent! Thanks for the info. I had no idea that those lines deteriorated over time and restricted flow. Gotta file this one for future reference.
posted September 15, 2006 12:27 PM
WOrse YET is the problem is a Flap that you put the line on 1 way and it may work and the other way and it does not work! Then The NOS SOlenoid was truly bad which covered this problem!
WHo said NOS was SImple??
Yes Randall will be riding also! We will dial it in with him and then I will Ride Sunday!
shiphteey
posted September 15, 2006 01:59 PM
VH: You goin Sept or Oct? I was gonna do both but it may be too packed w/the 150 mph/streetbike class....maybe just hold out for October w/magnesium wheels!
A.
Gemini Motorcycles
posted September 16, 2006 05:43 AM
I understand about the "STreet Bike Class" But I NEED to go and get this Bug off of my Back. Over the WInter I am going to install the OD Gears and strengthen the Lower end the ARP Studs I have and maybe go to 1/2 inch Cylinder Studs so that I can more safely spray a 200 to 250 Shot of NOS
I do not know what the Limit of Spraying is but I plan to find out so I also plan to order a set of even thicker topped Pistons and another Cylinder.
TRNorBRN6001
posted September 16, 2006 06:02 AM
Mr. Hill that's a heavy hand of nos!!!!!!!!! Can't wait to see it go!!!!!!!!!!! When your doing your rebuild you might want to check out Calico Coatings, they have a nice selection of thermal coatings for piston tops, exhaust ports, valves, and chambers. Might help to keep the heat out of the head, off the intake valves and out the exhaust. They also do Black or Chrome type ceramic coats for headers.
posted September 16, 2006 06:13 AM
Thanks Dr. Gary! I have always said that the Power limit of a 4 stroke engine is the Exhaust Valve's ability to handle heat! I will "Seriously" look into that because I am going to have a serious amount of heat to deal with!
harryzx-12
posted September 16, 2006 02:06 PM
http://www.calicocoatings.com/index.phtml?coatings
osti33
posted September 16, 2006 06:08 PM
Good luck Mr Hill and Harry! Kick some ass guys!!
posted September 16, 2006 06:43 PM
Be Careful in talking to Harry Too close to Lick some Ass
harryzx-12
posted September 16, 2006 06:56 PM        Edited By: harryzx-12 on 16 Sep 2006 19:57
Don't get me started on your ass vincent! That was kick, not lick. I won't be kickin no ass. I'm just going to get as many qualifying passes in as i can. I will be very happy to make it above 175 mph.
Next time i go i hope my turbobusa is sorted so i can go over 200mph. I think i can do that with the hp the busa has.
posted September 16, 2006 07:04 PM
Have a blast guys!
posted September 17, 2006 05:57 AM
Glad to see that you have to get "Started" I thought it was all of the time Harry you should make it close to 180! If not, then we will have to make a tank for you like the one on my bike that allows Space for the front part of your body!!
posted September 17, 2006 04:54 PM
Flow testing over! I have NEVER Seen this much NOS dissapear out of a tank! The Bike is together and will dyno early this week (Between Monday and Wednesday so I cal fill all of the Bottles and get more fuel. It looks like I will be using about 2.5 to 3 pounds of NOS Per run so I plan to get another 5 pound bottle so I will have 3 - 5 pound and 2 - 10 pound
Anyone need 1 oe 2 - 2.5 pound Bottles ?? Ali? (Ali I will loan then to you with Option to Buy! )
shiphteey
posted September 17, 2006 05:44 PM
Thanks for the offer VH. I have 1 10 lb bottle and 2 2.5s, which suits me fine....for now. I am thinking about more nos or going into the motor this winter and I too will be looking at sizes/quantities similar to your set-up.
But it may be a good idea to take it w/you filled up...ya never know....maybe you or someone else will need it after all....
A
Gemini Motorcycles
posted September 17, 2006 05:57 PM
OH Oh! Glad I finally fixed my stuff and have good plans over the WInter for FINALLY Installing my OD Gears and Case studs. No for sure I am going with the 1/2 cylinder studs so I can spray over 200 just to keep up with you!
Without modifications you can set up 2 -2,5 Bottles 1 in the tail section and 1 in a Swingarm
wannabe
posted September 17, 2006 07:31 PM
By the way, Vincent. I want to hear all the details on your nitrous setup when you get back. I missed a lot of your older posts about the system while I was away from racing. Now that I'm wanting to spray my motor, I want all the details that you can give me.
I may also be interested in buying those 2.5-lb bottles from you when you get back.
Good luck!!!
posted September 18, 2006 04:56 AM
Good luck!!!
Trial and Stupidity is what I have!
I have just gone throught the "Trial" and now see what I was Stupid about! (Never checking the Flow from the Bottle to the system 1 piece at a time!)
Simple, Get an NX Motorcycle kit for about $600 somewhere with the Braided lines (List a little higher). Use that as your Basis. Schnitz Ignition and NOS Controller. Chuck Wilburn NOS Pressure COntroller. Then decide if you want to direct inject (Drill the throttle bodies one of the Vacuum ports) or blow through System (Bear Stacks is what I used) all in the Airbox)
The only thing missing here is the Fuel! I made up something to avoid using a spearate fuel pump and went through a lot to develop it. Buy a good MPS Nos Button (I broke the trash one I had an at a time the bike was going 199 I could have gone 202!
The Bottles are yours
0.23234605789185 seconds processing time
