BIKELAND > FORUMS > ZX12R ZONE.com > Thread: oil pressure NEW TOPIC NEW POLL POST REPLY
NINJA12
posted September 17, 2006 06:02 AM
oil pressure
Doug Spencer mentioned the low oil pressure of the zx12 at idle.
But I didn't pay it much attention until a few night ago.
I put alittle oil guage in place of the oil pressure sending unit for the oil light.
Less than 10 psi !
I don't think I will ever run my idle less than 14-1500 rpm again.
Wal-mart carries a oil guage for ~$10 with everthing you need to test this for yourself.
I'm considering during a permant mount for the guage off a tee to keep the light.
It will make you change the way you handle your baby.
krexken
posted September 17, 2006 01:30 PM
Just checked one the other night with hot 10-40 in it at idle. 5psi! Around 35psi at 4 grand though. 70 when wacked.
posted September 17, 2006 11:39 PM
yessiree, after putting a permanent guage on it and seeing low #'s when hot, i set the idle at 1500 or higher.
Also,
Mobil-1 helps out quite a bit as it seems the keep pressure better when it is hot.
TRNorBRN6001
posted September 18, 2006 06:15 AM
That's kind of low! You would think someone would have made a gear or oil pump to increase the pressure a touch. Guess it's too late with the 12 on the out's and the 14
on the scene.
TFA 200MPH CLUB MEMBER!
psycho1122
posted September 18, 2006 07:07 AM
Also,
+1!!! Mobil1 15w50 does a great job of retaining viscosity when HOT.
ninja12
posted September 18, 2006 08:58 AM
Just wanted to get the word out that we could be during damage with the low idle.
I know i love the big cam lope but not at the expense of my engine.
TRNorBRN6001
posted September 18, 2006 09:11 AM
Yep, I use to run a low idle and have that lopey sound.
five 0
posted September 18, 2006 06:18 PM
We have been running gauges on the cars since 2000. The 12 has very low pressure when hot at idle. 10psi would be good. Dont let this scare you, they are all low like that.
5-0
0.25759506225586 seconds processing time
