BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 2000 12r motor needing crank work NEW TOPIC NEW POLL POST REPLY
suzukidude87
posted September 04, 2006 06:46 PM
hello, what do you guys think a 2000 12r motor is worth that the number 3 rod bolt backed out on and caused a barring falure, also crank will need work because of it. no clutch basket in the motor, this deal will be sight unseen, Im thinking of a trade for it just wanting to know what you guys think its worth cash wise. thanks!
thanks GOD for blessing us with bikes!
posted September 04, 2006 11:38 PM
worth depends on if the cases are injured (likely), and whether the head/valves got touched. How many miles, what kind of use? Does the ECU & wiring harness come with it? Stock pistons, cams & head?? Main bearings OK??
fixing one rod bearing is one thing; replacing the cases and repairing the head a whole other story.
need more info.
psycho1122
posted September 05, 2006 09:37 AM
Rod "bolt" Backed Out?!?!
How were you able to determine if that was the case?
We have seen these claims here before and turned out not to be the case.
suzukidude87
posted September 05, 2006 12:04 PM
hay fellas thanks....... I did not persue this any more, I figure I should pass on this one,
TRNorBRN6001
posted September 07, 2006 09:29 AM
Is it usually the thrust bearing surface that goes bad on cases?
TFA 200MPH CLUB MEMBER!
0.30345296859741 seconds processing time
