BIKELAND > FORUMS > ZX12R ZONE.com > Thread: One more clutch install question NEW TOPIC NEW POLL POST REPLY
Big_Zx12r
posted April 26, 2002 12:36 AM
OK....I have been looking through all the "archives" for info on my muzzy clutch install next week. I still have a few questions I couldn't find answers to.
I need to buy a Impact gun so.....how many ft/lbs is that big clutch nut gonna take to come off? Will a 200-230 ft/lb impact gun do the trick....or do I need to go with the 400 ft/lb?
I was told I do not need a "clutch holding tool" to take this nut off (just a little boot or hand pressure to hold the assy in place)...is this correct? Also...Do I need to torque that nut down to a certain spec or just use the torque wrench and wrap it a few times? (I know I need to torque the springs to 78 inch lbs)
That should be it......thanks for the help!
-Big_Zx12r
iflyguns
posted April 26, 2002 02:01 AM
This should answer all ?'s!
http://www.spencercycle.com
Go to, "how to" section for cltch install!
Tony D
slug
Out in search of my mind...
posted April 26, 2002 03:21 AM
i guess you wouldn't need clutch tool when using impact wrench. a word of caution though, ive seen a LOT of galled threads from use of impact wrench. especially on 'precision' machined parts. quick & easy does have its risks....
also if bike is in gear and friend there to help hold it in place you can probably break it free that way as well.
i broke my clutch boss trying to get mine without paying for tool, sucked a big one, one month backorder....tool got here quicker than the new piece..hehe
  Ignore this member    Click here to send Slug an ICQ message. Click here to add 1734970 to your ICQ list. Click here to visit Slug's homepage. Click here to send Slug an AIM message.
12RPilot
posted April 26, 2002 05:45 AM
Damn near any impact wrench will spin it off. Don't need a special tool to hold it for that. I personally would not put the thing back together with the impact wrench. In fact I feel pretty strongly that doing it with the impact wrench is bad practice. Torque wrenches are not too expensive considering the peace of mind they give you.
NESBA #209
Big_Zx12r
posted April 26, 2002 06:27 PM        Edited By: Big_Zx12r on 27 Apr 2002 11:42
12RPILOT,
OK....maybe I am missing something but how will I torque that nut down without a tool to hold the clutch in place? (I know the impact gun will work because of the fast "wrapping" action)but can you actually hold the clutch assy while torqing down that nut? Oh...and about how much torque then?
Torque wrenches scare me too but that is how it "appears" Doug@spencer did it.
IFLYGUNS,
I checked that out when you sent me there before.....Great info and I appreciate it but.........I can not see anywhere in there where it shows or says how he put that "Nut" back on (Impact gun or Torque wrench? & how much torque)...that is why I re-posted for these questions.
Thanks for the info so far!
-Big_Zx12r
***MadMike....where are ya at....I know you do this like every two weeks....hell,you most likely do it while sleeping at night ....any input? Thanks!
posted April 27, 2002 12:27 AM
100# on clutch hub nut. I bought the Kwak tool which holds the hub a year ago and really am glad I did since I have had the entire assembly in/out several times, and don't like using an impact on it.
Thr latest experiment is that I had a machinist take .020" off the hub height so that the hat has a little more room before bottoming out.. This'll prolly work about as well as my other experiments but, hey why noy try?
slug
posted April 27, 2002 06:29 PM
big zx12r where are you located? if close enough you could borry my clutch tool....
0.40768504142761 seconds processing time
