BIKELAND > FORUMS > ZX12R ZONE.com > Thread: how the F%#$ do you remove the stick coils? NEW TOPIC NEW POLL POST REPLY
frEEk
posted July 12, 2006 08:01 PM
do u just pull them up plain and simple? they seem to be on there pretty good and i'm worried about breaking something. not to mention, iwll tehy even come off without the engine dropped?
osti33
posted July 12, 2006 08:06 PM        Edited By: osti33 on 12 Jul 2006 21:07
Just pull straight up. If you have trouble you can pry on them a little with a screwdriver.
and yes the will come out without dropping the engine.
frEEk
thx osti
osti33
posted July 12, 2006 08:08 PM
No problem.
I have found it easier to twist and pull...
12r1
Yes, they do just pull straight out, and can be taken out with the engine in place. Have to bend them a little, but no big deal. There's a looong rubber end on them.If they're really tight, you'll have to twist them back-and-forth a bit to pull em out. A small shot of WD40 won't hurt either. I smeared a bit of synthetic grease on them on re-install.
jeff
blitzkrieg
Road kill = Free lunch.
posted July 12, 2006 09:19 PM
Do the Twist!!!
Opposite of fucking. Twist and pull out.
posted July 13, 2006 05:29 AM
When putting them back in make sure you put a pry bar against the frame and on top of the coil to make it snap back in, it's important to make them snap in!!!
warbird
posted July 13, 2006 07:40 AM
frEEk...............I twist mine around 4 or 5 complete revolutions ( usually counterclockwise cause I am silly........) then pull up on em. It helps break em loose since most have been on there a while. When I install them.........I turn them clockwise 4 or 5 times ( cause I am silly...... ) while pushing down to ensure they are seated.........
This is the procedure that Yamaha recommends in there service manuals.........
I'd Rather Be Roadracing.
OutsiderzX12r
Street Racer
posted July 13, 2006 07:44 AM
+1
OutsiderZX12R
2000 ZX12R-A1
  Ignore this member    Click here to visit OutsiderZX12R's homepage.
warbird
posted July 13, 2006 08:34 AM
"This is the procedure that Yamaha recommends in there service manuals......... "
and seems to work well on the 12's......... ( had to split suddenly during the above post........my 2 year old was running around with a 1/2 gallon of apple juice he swiped out of the fridge............ )
Wideout
posted July 13, 2006 11:27 AM
Make sure they snap twice when pushing them back in.
+1 on having to bend some of them once it reaches the rubber part.
your car is slow
Fuck Nitrous...Got Boost?
posted July 13, 2006 03:12 PM
i used to use a long set of needle nose pliers and a dowel to lever them up.
extremelean
posted July 14, 2006 05:19 PM
TOO MUCH INFORMATION !!!!!!!
thanks
frEEk
posted July 14, 2006 10:18 PM
they back in. man what a pita. alot easier to get teh valve cover on and off with the rad pulled btw.
0.25514698028564 seconds processing time
