RAC4IT
Bergie
posted June 16, 2006 12:40 PM
19-Tooth Front Sprocket Questions
VH (or others with the 19-tooth custom front sprocket for LSR)-
When you install the 19-toother, did you completely remove the front sprocket cover or modify it? If you modified it, please post a pic.
Did you have to seperate the chain to get it to clear during the install or will it slip on with the chain like normal?
-B
harryzx-12
posted June 16, 2006 12:49 PM
I have a 20 tooth on the front but no cover. You can just change sprockets without seperating the chain. Don't know about a modded cover.
RAC4IT
Bergie
posted June 17, 2006 02:31 PM
20 tooth? Where did you get that?
posted June 17, 2006 03:58 PM
Bergie, The steel ring that protects the case inside the cover has to be removed and modified
Measure 1/8 inch all of the way around (Not on the ends) and grind away this 1/8 inch and everything will work perfectly! I used a grinder to remove the main part and a Dremmel stone to get shape and samding drum to finish! Reinstall and go race!
your car is slow
Fuck Nitrous...Got Boost?
posted June 18, 2006 12:43 AM
front covers are overrated!
posted June 18, 2006 03:56 AM
quote: front covers are overrated!
SOmething better than Nothing and keeps the grease off the engine
Bergie, no the chain does not have to come apart!
RAC4IT
Bergie
posted June 18, 2006 09:49 AM
Thanks, do you have pics of your modified cover?
harryzx-12
posted June 19, 2006 01:28 AM
The motorhead had a batch of 20t sprockets made up awhile back.Doesn't turn much rpm on the interstate!
posted June 19, 2006 07:22 AM
quote: Thanks, do you have pics of your modified cover?
You would think I would!! I will take a look at someof the CD's I have. My guess is that the 256 Memory Card I had that went bad is where they were!. Start in the center of the steel ring and measure back 1/8 inch and make a mark around the rest of the ring and remove the Metal.
