BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Pulling down motor, need manual! NEW TOPIC NEW POLL POST REPLY
zx12adam
Member
posted June 13, 2006 09:14 AM
I've decided to pull the heads off my 12 and get the valve guides and valve guide seals replaced, possibly the piston rings, but I need a manual, is there anyone here looking to sell theirs? The engine burns oil on start-up, just a quick puff of smoke on initial start-up and clears right up. Doesn't do it again until it sits for awhile(possible oil draining into combustion chamber from valves?).
I think I remember someone pulling the head off thier 12 without pulling the engine out the bike, doesn't seem impossible as long as there's enough clearance under the frame. Anything in particular to look out for? Is it possible to check the valve clearance with the head out? I have experience with pulling car motors and wrenching on them and I'm looking forward to learning the insides of the 12's motor.
CBR1000RR
Best Literbike: Performance Bikes, Superbike, BIKE, MCN, Road Racing World, and Motorcycle USA
wylde
posted June 13, 2006 09:19 AM
you can dowm load it from ZX12R.Org at the bottom of the screen there are two skulls,, one is the manual,, the other skull is a parts microfische.
http://www.zx-12r.org/easyriderGenInfo.shtml
copy and paste this link at the bottom you will see a piston looking thing,,on either side of the piston looking thing hold your cursor and you will get either the manual or microfische.
if you have a problem call me and i can walk you through it on the phone 702 591 7277
Vic
There you go again,,NOT being aware of yourself !
zx12adam
Member
posted June 13, 2006 09:45 AM
Thanks Vic.
CBR1000RR
wylde
posted June 13, 2006 09:57 AM
did ya find it ok,, if so no problem bro..
zx12adam
Member
posted June 13, 2006 01:35 PM
My dial up connection is telling me it'll take 5 hrs to download, with the power going in/out from this weather it's not going too well. But thanks anyways Vic.
CBR1000RR
wylde
posted June 13, 2006 02:17 PM
Well maybe you can use someone elses computer with a broadband connection and throw it on a flash drive or sumthin.. just save the link! some good stuff over there too...
harryzx-12
posted June 14, 2006 09:36 AM
Go by chucks and get mine adam. His # is 752-1242. I'll get it from you when i get back.I'm back from the IOM. Just got here about 15 minutes ago.
Y2KZX12R
CompetitionCNC.com
posted June 14, 2006 11:08 AM
More than likely you will see the oil coming from the air port in the exhaust port.
Look into all 4 of the exhaust ports and you will see one or two or all of them wet with carbon/oil. When you look closer you will see that its actually coming from the air ports and not the guides. some or all ov your valves that have this oil leakage will be crusted up. This hurts exhaust flow bigtime. If you have blocked off the air system for the exhaust system as most have, this creates a slight suction and draws in oil past the seals between the head and valve cover. Remove the blockoff plates and you will most likely see oil in there. This is why its important to replace the "sparkplug" hole gaskets for the valve cover. Thats your source of oil in the exhaust and your smoking.
Even if you have new gaskets and are using the blockoff plates, you should either tap the head passages and plug them or clean the passageway from the valve cover side and inject hightemp silicone sealer inthere. This will stop the oil for good. I went thru this as have several other members on here. I just cleaned the passage way real good with paint thinner so the steel tube insert was squeeky clean and filled the top 1" or so with silicone.
Y2KZX12R
CompetitionCNC.com
0.34478998184204 seconds processing time
