BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Clutch compatibility NEW TOPIC NEW POLL POST REPLY
jmorgan
posted May 18, 2006 08:33 PM
I need to upgrade my clutch on my zx12-powered sandrail. What I need to know is will the Muzzy clutch kit, a MTC two stage lockup clutch and a Falicon billet basket work together? Right now I just have nitrous on it and the clutch is slipping. Later this summer it will have nitrous and a turbo.
Jason
posted May 18, 2006 09:27 PM
Yes, should work fine...
mlb
posted May 19, 2006 08:22 AM
that sounds like a nasty sand rail, must be a blast to drive...
droid
posted May 19, 2006 09:39 AM
Any pictures??
countersteer
Didn't read the owners manual
posted May 19, 2006 02:56 PM
you would want a lock-up clutch on a sandrail?
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
zxlnt
posted May 19, 2006 03:01 PM
Sure if its the only way to keep the clutch from slipping. What other choice is there????
wannabe
posted May 19, 2006 06:49 PM
why would you need the stiffer springs in the Muzzy kit if you are getting a lockup? Or, do you already have the kit in the bike?
jmorgan
posted May 19, 2006 09:29 PM
I will post a few pics later don't have time right now. As of right now it has the stock clutch in it. I wanted to get the muzzy kit to cure the dry clutch problem and I'm going to need new clutch anyways. When it put the lockup in it I will run the stock springs. So has anyone run this combo, I don't want to spend over $1000 and the parts not work together.
wannabe
posted May 19, 2006 09:59 PM        Edited By: wannabe on 19 May 2006 23:00
I don't know. If I were you, I would do one thing at a time. Start with much stiffer springs then go to the lockup if that still doesn't work. I'm assuming that since it's in a sand rail, you have it set up so that your left leg actuates the clutch, right? So, you don't have to worry about your hand not being strong enough to pull in the clutch lever with stiffer springs.
Even with the MTC lockup, I'd still be kinda sketched out about having to pull the clutch in at higher RPM's. And, since you're not just dragracing, needing to pull in the clutch at high RPM's is a definite possibility, right?
jmorgan
posted May 19, 2006 10:39 PM
This car weighs 920 lbs and has two 26 inch tall 10 inch wide paddles pushing it around. The only time I use the clutch while driving is to take off and to stop. My plan is to get the muzzy kit and the billet basket right now and run six of the muzzy springs. That should hold the 40 shot of nitrous. When I add the turbo later I will need the lockup.
countersteer
posted May 20, 2006 02:07 PM
pics?
Scott
jmorgan
posted May 21, 2006 08:40 AM
Here are some pics
jmorgan
posted May 21, 2006 08:49 AM
Well that did not work I'll try again
your car is slow
Fuck Nitrous...Got Boost?
posted May 21, 2006 12:20 PM
that looks fun
posted May 21, 2006 01:31 PM
Cool..
ninja12
posted May 22, 2006 05:45 AM
Now that looks like fun!
I want one.
matt sterbator
Hiding in the bushes
posted May 23, 2006 01:05 PM
wait til Kristen sees that... and we have two donor 12R motors, lol
jmorgan
posted June 09, 2006 09:45 PM        Edited By: jmorgan on 9 Jun 2006 22:47
I got the last part to my clutch today. I went ahead and got a muzzy clutch kit, a mtc two stage lock-up and a falicon basket.
I got it all put together and am going to test it tomorrow.
zxlnt
posted June 09, 2006 10:45 PM
Ooooh Pretty parts!!!
0.24910593032837 seconds processing time
