BIKELAND > FORUMS > ZX12R ZONE.com > Thread: 12R injectors NEW TOPIC NEW POLL POST REPLY
keith
posted October 13, 2005 08:41 AM
12R injectors
I want to upgrade my stock injectors because they are running close to maximum on the dyno and I want to be able to add some more gas next season. At the moment I've only tried a 60hp shot. Anybody got any info on alternatine injectors. Thanks, Keith
rac4it
Bergie
posted October 13, 2005 10:20 AM
60hp dry? How much power are you making? Stock injectors are fine to 300+ rwhp.
your car is slow
Fuck Nitrous...Got Boost?
posted October 13, 2005 10:52 AM
RC 700s dont fit without some serious work :/
Do not taunt happy fun ball!
posted October 13, 2005 11:04 AM
By the looks of that statement, it must be first hand knowledge
psycho1122
posted October 13, 2005 04:28 PM
Have them Serviced at RC Engineering and add a Muzzy Fuel Pump.
DONE
keith
posted October 14, 2005 12:24 AM
I've got the Muzzy pump, can have them serviced over here. Thanks for your help guys. Keith
keith
posted October 14, 2005 12:25 AM
Bergie - my 1270 made 265 rwhp with 60 hp jet.
justoyz2
Justoyz Racing
posted October 14, 2005 03:53 AM
call Wayne at RC Engr. They has several sets, you stock injectors is 30lbs(310cc)
They have some 330 / 440 and larger injectors. 330 should be fine, but the 440 are only a buck or two more
posted October 14, 2005 04:46 AM        Edited By: entropy on 14 Oct 2005 08:14
justoyz,
good to meet you at Memphis!
do the 330/440 fit without mod to the frame??? pretty close fit even for the stockers, eh?
your car is slow
posted October 14, 2005 06:30 AM
heh...a 205hp 1270? thats a happy dyno!
posted October 14, 2005 07:10 AM
Maybe Standard HP or "Uncorrected" HP
rac4it
Bergie
posted October 14, 2005 11:32 AM
regardless point is you don't need new injectors for your current nitrous setup
my setup makes 290rwhp on stock injectors no problem with room to go
dont be scared
Ra12r
posted October 14, 2005 08:01 PM
YCIS, it must be a Kcadby 1270............
aliveagain
posted October 15, 2005 05:01 AM
Someone enlighten me a little on injectors.I know they are either open or closed and just regulated by time but will the size influence the atomizing effect by having more holes?Or is the smallest size to fit needs the best?
ninja12
posted October 15, 2005 05:08 PM        Edited By: ninja12 on 15 Oct 2005 18:13
With a given fuel pressure the size of the injectors will influence spray pattern and the ability to control it effeciently. Small injectors are duty cycle limited on the top end.
Large injector tend to have some idle and drive issues.
To a degree smaller is better as long as you have enough. I think 85% duty cycle is the max recommended hp but many exceed that.
aliveagain
posted October 15, 2005 07:10 PM
thanx,good to know
0.39904093742371 seconds processing time
