BIKELAND > FORUMS > ZX12R ZONE.com > Thread: rod bolts NEW TOPIC NEW POLL POST REPLY
keith
posted August 03, 2005 10:29 AM
rod bolts
Broke a rod bolt and wiped the motor. Any ideas on improving the stock rod bolts. Muzzy 1270, 200 rwhp on 98 octane unleaded. Keith
osti33
posted August 03, 2005 10:57 AM
How do you break a rod bolt? Was it torqued properly?
RAC4IT
Bergie
posted August 03, 2005 12:17 PM
yep; bad install
no factory rod bolt is going to break under 300rwhp
psycho1122
posted August 04, 2005 06:44 AM
OH NO!!! Not this issue again?!?!?
More info keith......Not a good idea to let this one get out of hand.
posted August 04, 2005 07:10 AM
were they new bolts? did you even touch the bottom end when you did the 1270?
Mad Mike
posted August 04, 2005 07:30 AM
Good Question Mike. "200" HP in a 1270? Must be Not corrected or Standard.
psycho1122
posted August 05, 2005 06:24 AM
My 1270 made 202 h.p.! Correction factor was 1.10 due to the 110+ heat and very low Barometer (29.70).
Now with less valve overlap, hp is down 10, however Torque is up 10 through the middle!
How about that all important additional info keith??
0.27473902702332 seconds processing time
