BIKELAND > FORUMS > ZX12R ZONE.com > Thread: radiator repair? NEW TOPIC NEW POLL POST REPLY
frEEk
posted July 28, 2005 07:36 PM
radiator repair?
so i've got a pinhole in my rad, in the fins, cause one of the motor mount bolts backed out. how do u fix that? do i need to take it to a rad repair shop or will a simple sautering iron and some specific sauter take care of it?
posted July 29, 2005 12:14 AM
You definately need to take it to a radiator guy...Probably have a hole in one of the water channels thats why its leaking...
The radiator guy will most likely block off that channel, not fix the hole...New radiator is $550.00...
I had a leak from the strap buckle that was rubbing against the radiator when I made right turns getting off the DragStrip...The radiator guy told me that he will block off that channel, because the aluminum is realy too soft to fix without it leaking again...So I opted for the new radiator!!!
0.3732738494873 seconds processing time
