BIKELAND > FORUMS > ZX12R ZONE.com > Thread: Yosh EMS Map NEW TOPIC NEW POLL POST REPLY
zxlnt
posted February 14, 2002 05:15 PM
Yosh EMS Map
Anyone have a map for the Yosh EMS for Muzzy with K@N's, also would be interested in same except for 1270 motor..
Hondo??
hondo
posted February 16, 2002 06:49 AM
I'm using the standard Yosh map for the Race Duplex. Halmeter indicates a little lean, 13.5 in a few places but it runs so good (throttle response) I've seen no need to change it. Will play with it this spring. The Yosh maps include the baseline/+ 5%/- 5%. Three choices with each map and you have to choose which one is the default. Me with my 3-way switch I have 9 choices! Still using the default!
hondo
posted February 16, 2002 06:56 AM
I didn't answer your question. A big guess, use the Race Duplex map to start. The pipes are so close in peak output that should get you started. I have a K&N also. You have the Yosh software, download the Dyno-Jet software from their site, it's free. Use the Dyno-Jet software to open up some PCIII fuel maps recommended for the 1270 Muzzy combo and compare it to the Duplex map. You can check each RPM and throttle position. Kind of cool. It's interesting how much alike the two software set-ups are. One could almost think the same person wrote them.
Tearinitup
VP Code Monkey
posted February 17, 2002 09:08 AM        Edited By: Tearinitup on 18 Feb 2002 12:16
zxlnt
posted February 26, 2002 03:23 PM
Ok I have a Muzzy map with stock stock filters made for the EMS. I have K@N's in my bike. What would be a good percentage to go from there on the fuel. +5 or +10 or less than that?? Also going to make maps with 2,4,6 degrees advance and see what works best on dyno anyway..
zxlnt
posted February 27, 2002 06:11 PM
Hondo here did u get the hub and switch from. My dealer is saying Yosh is telling them not available.
iflyguns
posted February 28, 2002 01:51 AM
Yosh EMS vs. PCIIIr
What the difference between the EMS and PCIIIr besides the price and is the EMS worth it and why?
Tony D
0.25773906707764 seconds processing time
