Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: HID's on the Connie NEW TOPIC NEW POLL POST REPLY
FastestBusaAround
I eat Fish...
posted May 03, 2009 08:31 PM        Edited By: FastestBusaAround on 4 May 2009 04:32
HID's on the Connie
Just installed a set of HID's on the C14 last night. Install was easy and placing the ballasts and ignitors was simple, with lots of room to spare. The 6000k white light of the HID is wild and puts way more light down to the ground than the stock halogens. I only had to raise the adjusters to get the beams up. The lights include halogen bulbs which sit on the side of the HID bulbs, but compared to the HID lows, are useless.
There's a huge difference over stock and now much less heat coming off the headlight lenses. I just need to find a set of white super bright LED's to replace the center lights and get everything nice and white now.
FYYFF!!!
Roman
Live 2 ride ride 2 live
posted May 04, 2009 12:13 AM
What brand is HIDs? And where did you buy it?
FastestBusaAround
I eat Fish...
posted May 04, 2009 04:04 AM
It, like most others is some Chinese no-name brand as I get them wholesale from distributors I do business with. The ballasts (2.5" X 2.5" X 1/4") and ignitors are very small and very thin, so they are simple in terms of placement. The actual HID bulbs are generally the same from one brand to another and don't change much from brand to brand.
I paid $115.00 CDN...and you should be able to get HID's online for around $125-150 USD + shipping from most online vendors. They are available as motorized units that "click" up and down for high and low beam, or as a dual bulb, one for high and another (halogen) for low, which would give you less trouble in the long term, as the solenoid (motor) operated versions tend to break after a while. You could also just buy the single version that have low beams only, which is probably enough, as the halogen high beams pale and don't throw much light when compared to the HID low beams. Either way, the low beams when properly aimed, will be enough for all your lighting needs. I just bought these because it was what they had in stock and have been the least trouble free over the term.
The install is plug and play using the stock connectors. All I did was tie wrap the wires in place to clean it up. No cutting or splicing is required for install.
FYYFF!!!
Roman
posted May 04, 2009 08:41 PM
Thank you for information, I tried to find HIDs before and I was confused, there is too many brands and different types, now at least I know that solenoid ones not a good choice. Thank you. .
TedG
posted May 05, 2009 08:30 PM
I think I want a set myself. When I get ready, I know who to ask before I buy.
If the Halogens are not all that good it sounds like the solenoid types should make the high beams more usable. Hmmmm.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
FastestBusaAround
I eat Fish...
posted May 05, 2009 08:32 PM
True, but not reliable at all from my experience, and more $$ for more problems. In fact, you don't ever need to use the high beams with the HID's in any case, so it's really a moot point anyway.
FYYFF!!!
Rifleman223
posted May 09, 2009 09:23 AM
I can get them from my cousing for around $95.00 and I pick it up tomorrow. I will install and tell you guys how it is.
FastestBusaAround
I eat Fish...
posted May 09, 2009 08:46 PM
Just make sure you get the thin ballasts, that way you can just velcro them to the top of the inner upper fender. That makes for a simple install, and you'll also have to tie wrap the ignition harnesses to the forks so they don't hit the bulbs, which stick way out of the rubber boot. You'll see what I mean when you install them. If you do it right, you'll be waterpoof at the bulb cover boot.
FYYFF!!!
worm~hole
posted May 10, 2009 11:47 AM        Edited By: worm~hole on 10 May 2009 19:50
...what kind of heat (if any) do the HIDs put out?...I'll assume glass lenses are good to go, but will the plastic lenses of bikes with equiped with plastic lenses survive extended use?
who would do us harm.”
-George Orwell
FastestBusaAround
I eat Fish...
posted May 10, 2009 02:09 PM
Much less than the Halogen's did. I changed the left side 1st and ran HID's on the left and Halo's on the right...they run at about 30-40% less heat than Halo's. They also require 20 watts less per side as well. They're a great add-on for any bike! The plastic lenses should last longer with HID's than with the stockers IMO...
FYYFF!!!
Rifleman223
posted May 12, 2009 09:09 PM
I just installed them and the difference is STAGGERING. This is a must for the C14! It was a cake install. My bulbs' harness did not really stick out. Have a lot of clearance.
FastestBusaAround
I eat Fish...
posted May 13, 2009 05:44 PM
Is the bulb sealed in, or do you have space in the boot where water can get in?
FYYFF!!!
Rifleman223
posted May 16, 2009 06:25 AM
I sealed it with silicone.
BIKELAND > FORUMS > CONCOURS14.com > Thread: HID\'s on the Connie NEW TOPIC NEW POLL POST REPLY
0.30777621269226 seconds processing time
