Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Storage lid on tank NEW TOPIC NEW POLL POST REPLY
Laguna D
posted June 23, 2008 08:48 PM
Storage lid on tank
Am I the only one having trouble with the tank storage compartment lid? I have trimmed down the plastic catches and put greese on the catches and I still have to push the open latch and pull the hinge end towards me to get it to open. I keep a garage opener in the compartment but can't open the garage door unless I put it in nutral.
How can I out run the police if I can't get the garage door open. :-)
Laguna D____________
cedric
posted June 24, 2008 01:29 AM
I had the same problem after removing the storage box and I found that if you loosen the screws that hold the box down and move it until it opens ok. I also have a garage remote but I used velcro to attach it to the underside of the black plastic between the storage box and the outer trim. You will have to extend the remote switch from the opener to a push on miniture switch which I secured to the black plastic strip and my remote operates up to 80 meters from the garage door.
Cedric
2007 Silver Concours
Helibars, Crash Protectors and Radiator guard.
garvin6
us citizen
posted June 24, 2008 08:31 AM
I too had trouble with that lid. One of the prongs that help keep it closed broke off and I was able to get it fixed under warranty, the new one is only slightly improved. You just have to be gentle in opening and closing.
Kevin F. Garvin
DB
posted July 03, 2008 04:15 PM
I'm having problems also. Sometimes it just won't open
Dan
04 ZX10r (Track only)
08 Concours14
robsong
posted July 04, 2008 10:25 AM
Had a problem with mine after first week. At least they did order me a new one under warranty. These arent very sturdy for the amount of use they will be getting. Got a feeling I will be buying several of these over the years.
TedG
posted July 06, 2008 08:35 PM
Mine used to stick and I just lubed the pins and it has been perfect since.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
0.24607992172241 seconds processing time
