Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: I like my Concours14 but....... NEW TOPIC NEW POLL POST REPLY
DB
posted June 18, 2008 04:02 PM
I really like my Concours14 but I'm on my 2nd warranty issue. This is my 10th new bike to own and all 9 of my previous new bikes had a total of ZERO warranty issues. I sure hope this isn't a sign of more to come.
1st warranty issue -- rear tire low air pressure battery defective
2nd warranty issue -- sometimes when I turn the bike on the digital dash is faded. Even different parts of it are dimmer then others. My dealer has a call into Kawasaki checking on it.
Dan
04 ZX10r (Track only)
08 Concours14
brunobp
posted June 18, 2008 06:11 PM
I think with most first year issue models there will always be little things. The more sophisticated they make these bikes, the more apt they are to have issues. Just my .02
robsong
posted June 19, 2008 06:05 PM
Digital dash fade could be from extreme heat if you leave the bike out in the sun for extended amounts of time. I saw one do that once, when the bike cooled off things returned to normal. Doesnt make sense that you can ride all day and no problem. I guess because things are cooler riding down the highway versus setting in direct sunlight. My serius radio does this when left on the dash in the sun. Who knows for sure.
AllStingNoBling
posted June 20, 2008 06:10 AM
If my bike is sitting in the sun too long, the LCD will be faded as well. It will return to normal contrast after a while though. Still, from what you typed, it sounds like something different altogether.
TedG
posted June 20, 2008 10:53 AM
The fading is a common problem with LCD displays in most everything. When they get hot they will fade and come back when they cool. Nature of the beast.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
haroldo_psf
posted July 14, 2008 07:50 PM
Has anyone nocited that the tire pressure on the dash panel is a couple of PSI off what you see on the gas stations pressure gauges? It's not a big deal, as I know that "40psi" really mean 42, but just something I noticed...
Haroldo
2008 C14 ABS
fASTESTbUSAaROUND
I eat Fish...
posted July 15, 2008 08:17 PM
Well...I have the cracked right mirror plastics issue, the two-hands-to-open-the-glovebox issue,..had my switch fail keeping the key stuck in all the time (they changed the entire switch)
As far as the TPS gauge being off...mine is bang on with three different gauges that I use. Make sure you only measure TP cold...and not after you've ridden the bike. Once you have done that, ride the bike for 30 seconds and see what the gauge says then. The TPS can be used as a relative measure if they're not spot on with your other gauges...but they should be right on.
FYYFF!!!
sykotek-c14
posted July 17, 2008 06:09 AM
I always cover my dash with a towel I keep in the tank box while parked. I do this to keep the windshield from branding the plastics any more than they already are.
Just this week for the first time I forgot to put the towel over the dash. When I started the bike after work the dash was extremely faded. This was definitely from the heat of the sun on the panel, since it never happened before and the dash cam back to normal after a few miles of riding.
It is not something a new dash is going to fix, it is a property of the LCD panel (same thing happens to digital watches, calculators, etc).
Steve
2008 Concours-14 (Currently Own)
1995 ZX600C (Currently Own)
2003 CBR1100XX (Sold)
2002 Shadow Aero 1100 (sold)
1981 CB650 (Gave Away)
2000 ZX11D8 (Sold)
1984 LTD440 (Rusted to Death)
1999 GSX750F (Totaled!)
1998 Shadow Tourer A.C.E. (Traded)
1982 Honda Magna V45 (Traded (Yes, really traded))
kawabunga_dave
posted July 24, 2008 07:35 AM
I've had my bike for a month now. I had to have the tire pressure sensor battery replaced. Also I had a dead battery problem. The dealer told me that I am not riding the bike enough. It sat for 1 week and the battery was dead to the point where it would not even jump it (it would start, but would not run without the jumper cable). The dealer recharged the battery and said there was no problem beyond that. They also said that because of the electronics on the bike, battery drain happens quickly when the bike is not being ridden. They suggested riding the bike at least 2-3x per week. I typically ride on weekends. This just doesn't sound right to me. Any suggestions?
TedG
posted July 24, 2008 08:20 AM
Tell your dealer he is full of shit and doesn't understand electronics. Please be more gentle than that. I can easily let mine sit for a month and it will start right up. 99 times out of 100 it is the battery, the terminals need to be clean and tight. This system has a heavy drain for a short while then it goes into a low current mode that can go on for weeks if not months. That is if the battery is in good shape. Batterys need to be charged right after the acid is put in them, if they filled the electrolytes and just let the battery discharge it can hurt the battery and some never recover. You may be able to trickle charge it and it may come back. Sometimes a heavy surface charge then a trickle charge will help.
Ask your dealer if he used a load tester on the battery. If they still insist on their bullshit call Kawasaki customer service.
Ted
The fast color!!
Green 2005 ZX10R
FastestBusaAround
I eat Fish...
posted July 24, 2008 10:09 AM
+1, with Ted on this. Tell butthead to check the battery cables...they were probably loose, morons. "ride it 2-3X/week"....LOL What dipshits!
Average current drain on this bike is well under 1ma...which is enough to let the bike site for 3-5 months without starting it...easily, and I do that every winter. My bikes never see a charger or a start from Dec-March. Your dealer is a butthead.
FYYFF!!!
oncourse
I hate flies!!!
posted July 24, 2008 02:51 PM
either, like said above, the connections are loose or corroded or the alternator is not charging. If it's running, even on a jumper from a non running vehicle, or stand alone battery, switch your display to battery volts and what does it read? Should be 14v plus..
Reguards,
Rob
2003 kx 500 SOLD
Charles Young
Mighty Joe Young
posted July 27, 2008 06:20 PM
My Connie sat for almost six weeks last winter and fired right up . No problems .
Mighty Joe Young COG# 8341
limey Hooligan
US/British/Canadian. Not easy!
posted August 03, 2008 07:24 AM
Strange thing is, I have exactly the same 2 issues.
Just bought my Connie last week and after the test ride I told the dealership that the rear tire pressure reading was all blanks "- - -", and the sensor must not be working or have lost battery power. Said they'd fix it, but of course riding yesterday I see that it's not fixed.
I also have experienced LCD fade out, but it's definitely a temperature issue. It was 102 degrees here in Dallas yesterday, and my LCD was fading out to almost unreadable after I had parked the bike. It came back though, once back in motion.
'08 Concours14 ABS
'01 ZRX1200R - Sold
'80 KZ1000 - Sold
drewherc130
posted August 04, 2008 01:03 PM
Yeah, I'm with ted and steve on the battery issue. Sounds like horseshit to me. My battery was dead on the showroom floor. When I purchased the bike, the dealer put in a new one. No problems since.
Like many of you said, I'm also seeing the digital readout fade at times, but certainly seems like a heat issue.
2008 C14, flies out, Area P-Carbon, BMC, PC3, Spencer Seat Mod, Alaska Leather, Helibars with Ram GPS mount, Nuvi 250W
"Life moves pretty quick. If you don't stop and look around once in a while, you could miss it."
0.24689888954163 seconds processing time
