Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: BMC Air filters NEW TOPIC NEW POLL POST REPLY
TedG
posted June 05, 2008 07:17 AM
BMC Air filters
Went looking for a new air filter for the C14, 20000 miles is way to long for the stock paper filter. And found that the C14 and the ZX14 share the same filter. So I ordered the BMC Standard filter. I have a BMC in my ZX10 and the initial quality seemed very good. Anyone tried this filter?
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
brunobp
posted June 05, 2008 08:18 AM
I had one on my ZX14 and was happy with it.
bikelee
posted June 11, 2008 06:45 AM
I have one also and it works great. You made a good choice. Lee
TedG
posted June 11, 2008 03:39 PM
I need to get the damn thing installed. I know good and well the paper has to be plugged up. It should make a difference on WOT.
Ted
The fast color!!
Green 2005 ZX10R
drewherc130
posted June 11, 2008 10:25 PM
How much did you pay for it?
2008 C14, flies out, Area P-Carbon, BMC, PC3, Spencer Seat Mod, Alaska Leather, Helibars with Ram GPS mount, Nuvi 250W
"Life moves pretty quick. If you don't stop and look around once in a while, you could miss it."
TedG
posted June 12, 2008 08:47 AM
$72.86
Ted
The fast color!!
Green 2005 ZX10R
oncourse
I hate flies!!!
posted June 12, 2008 05:55 PM
At the same time you remove the flies you should install it, that way you can get 'em both done and grin
Rob
2003 kx 500 SOLD
TedG
posted June 13, 2008 10:04 AM
The more I think about the fly thing the less I like any of the options. I am a electronic/software engineer. I have made literally hundreds of hardware related embedded systems. So many in fact that most likely everyone here has used something I invented/developed.
Removing the flies and a PC is OK. A TRE and a PC would be OK except for the gear indicator.
I am thinking the best route for me is to build a hardware(electronic) interface that will:
1. Intercept the signals to the stepper motor.
2. Mimic the secondary throttle position sensor.
3. Actually reposition the flies.
4. Tell the ECU the to richen the mixture (at the proper time of course) by telling the ECU it is at a lower altitude.
5. Be plug and play.
I am in no hurry to do the flies, I fuckin hate the PC (not so much the PC but their service). There are tons of proto boards with processors out there that can handle the I/O required. I have or can make the equipment to snoop and log what the ECU needs to see so it thinks things are perfectly normal. And it is not that big of a deal to figure out where it needs to be richened up and mess with the barometric sensor input.
And finally I have a bit more time to work on things, and I need a good project.
Ted
The fast color!!
Green 2005 ZX10R
TedG
posted June 13, 2008 09:25 PM
Shit, piss, fuck, cunt, cocksucker, motherfucker, and tits. They sent me the wrong air filter. Tore all the plastic off just to find they sent the wrong one. While I was in there I decided to check the exhaust nuts. 1&2 were finger tight, 3 had fallen off and 4 was snug. Tighten those nuts.
Ted
The fast color!!
Green 2005 ZX10R
leif
posted June 14, 2008 01:54 AM
Ted, what about nuts 5, 6, 7 and 8? Unless i'm thinking about the wrong nuts....
I did my own 600 mile break in check-up and all 8 nuts on my exhaust were pretty tight, I couldn't move them much. I checked all the bolts and nuts the service manual says should be checked and they were all tight and torqued. Guess I was lucky....
That sucks about the air filter.
Leif
oncourse
I hate flies!!!
posted June 14, 2008 08:27 AM
I think he was talking about cyl numbers, unless you have a 8 cyl concours, nahhhh be way to heavy. Bike is heavy enough and am still working on slow speed manuvers, once she is going it's a dream!
Sorry about the air filter Ted, hopefully you at least blew out the old one to make the time worth while...
Rob
2003 kx 500 SOLD
oncourse
I hate flies!!!
posted June 14, 2008 08:30 AM
One more thing, Ted that post above was to entice you, sometimes people need a little kick to get 'em going. I have no doubt that you can pull this off. Just watch that 17/1 fuel mix at around 3500... My ears and eyes await your findings, ok my mind too :-)
Rob
2003 kx 500 SOLD
Leif
posted June 14, 2008 03:55 PM
Ah, I see, 2 nuts per head...my bad.......
TedG
posted June 14, 2008 08:22 PM
I was talking about cyls. And yes I blew out the filter and it actually came pretty clean. So I will send back the other one and get is changed out. As far a my method on the flies I think the first thing I am going to do is put in an oxygen sensor to see how the thing does stock. That should help with the programming later.
Ted
The fast color!!
Green 2005 ZX10R
0.27782011032104 seconds processing time
