Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: how do you keep you battery charged? NEW TOPIC NEW POLL POST REPLY
oncourse
I hate flies!!!
posted May 01, 2008 04:08 PM
I was thinking of cutting off a direct 12v adapter (not a cell phone adapter etc) and use the power outlet to trickle the battery, Has anyone done this? I am sure it would work, mind you it is on a 10 amp outlet so use a small charger, but I think it is waaaayyyy easier than removing the cover to the battery.
Make your own charger adapter.....
Rob
2003 kx 500 SOLD
wormgear
posted May 01, 2008 05:39 PM
I just ride it all the time.11.5 k miles since Dec.
I dun need no steenking charger!
BUT I think the power outlet is dead with the switch off, No?
GodDamnit there's always such a big temptation to be good, to be good! (Tom Waits)
oncourse
I hate flies!!!
posted May 01, 2008 05:57 PM
Good question, I dunno either, but will check it this weekend.... If it is hot all the time I am definantly getting a lighter to fit the socket as well.!!
Will let you know...
Rob
2003 kx 500 SOLD
BFDeihl
posted May 02, 2008 12:57 AM
Wormgear is right--- the power outlet is switched. (Won't work as a charger port).
oncourse
I hate flies!!!
posted May 02, 2008 02:06 AM
Thanks for the info, will have to try a new approach!
Rob
2003 kx 500 SOLD
TedG
posted May 02, 2008 07:34 AM
What I use is the plug that I put on for my heated gear. Hooks directly to the battery.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
FASTESTbusaAROUND
I eat Fish...
posted May 02, 2008 04:43 PM
I never charge it, even after months of non-use and I've never had any issue starting it.
FYYFF!!!
oncourse
I hate flies!!!
posted May 03, 2008 06:40 PM
That Batt. has to be $$$$expensive, I wish I could ride all the time, summer is coming soon and then I will. The klr gets 70 mpg, even with all the mods. The c14 gets 42, still better than my little mazda!
Rob
2003 kx 500 SOLD
Wildman
I only look confused
posted May 05, 2008 05:13 AM
I just hooked up my Battery Tender to it. The battery isn't that hard to get to on this bike. I leave the lead where I can get to it without removing anything, but you cannot see it. It is tucked up underneath the plastic near the battery box.
When I pull into the garage, I plug it in. Easy, pretty cheap, and no home engineering required.
If you build something Idiot Proof, The world will build a better Idiot.
drewherc130
posted May 15, 2008 12:59 PM
When I bought my bike, the battery had died while on the showroom floor. The dealer put in a new one and I haven't had any problems since.
WIldman sounds like he's got a good idea, if you're not able to ride enough to keep it charged.
2008 C14, flies out, Area P-Carbon, BMC, PC3, Spencer Seat Mod, Alaska Leather, Helibars with Ram GPS mount, Nuvi 250W
"Life moves pretty quick. If you don't stop and look around once in a while, you could miss it."
fury
posted May 17, 2008 09:52 AM
I put a 12v adapter on my bike, and wired it directly to my battery.
Should be easy enough to back feed it to the bat.
It the stock unit will not allow u to do it. Install another unit.
I wish I had 2 units.
Electric gloves and vest would be nice here in the spring and fall in Ont.
08CC14
posted May 19, 2008 05:48 PM
'08 ABS Concours 14
'97 YZF600R
'00 ZX6e (rideable but needs paint)
0.23766088485718 seconds processing time
