Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: FOB Problems..... NEW TOPIC NEW POLL POST REPLY
bigfatboss
posted November 23, 2007 07:45 PM
FOB Problems.....
So anyways I started my trip from Utah to Ft Lauderdale Florida on Sunday and other than I froze my ass off for the first three hours of the ride I pulled into my destination safely on Wednesday noon. I did have a problem until Tuesday morning when I stopped after a 100 miles to fill up. I shut the bike off to fill up and when I pressed the ignition switch to turn the key to the on postion and nothing happened. At this point I was 50 miles west of Amarillo Texas so I called the Kawasaki dealer there and started to prepare to get my bike towed there to be fixed. They called me back a couple times trying to diagnose the problem but to no avail no start. So after trying a few times I finally got it to turn on and start. At that point I called the Kawi delaer and tow truck and cancelled them as I had to be in FL on time for Thanksgiving with the family. I prayed it wouldn't be a problem anymore but it did turn out to do the same thing again one other time. Unfortunaltely I have to drive back to Utah now and the confidence level is low on this bike now. I am going by a Kawi dealership tomorrow as I need tires and I will mention the FOB probelm to. Anyone having any issues like this?
TedG
posted November 23, 2007 08:17 PM
First of all did you try removing the hidden key and placing the fob on the switch? Maybe the battery is going south.
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
rifleman223
posted November 24, 2007 05:17 AM
Shouldn't the display indicate a low battery?
posted November 24, 2007 06:56 AM
I believe ted is suggesting the battery in the fob is low...
good thought!
rifleman223
posted November 24, 2007 08:26 AM
I saw that, that is why I was suggesting that. If the FOB battery is low, the display on the bike will indicate it.
Sorry, too vague of a reply from me.
bigfatboss
posted November 24, 2007 10:34 AM
Yes I did remove the hidden key and placed it over the ignition as suggested in the manual and it did nothing. It works now without a problem but it makes me uneasy that I couldn't locate the problem and I will be hitting the road on Wednesday.
TedG
posted November 24, 2007 12:27 PM
First of all I would take the spare fob and remove the battery and store it somewhere where you wont lose it. Because it your problem is a fob problem, at least you will have another one for a backup. I would also try to remove the battery on your main fob and try to start the bike with the fob indexed over the switch just to make sure the RFID is actually working.
Prudence demands that you at least remove the upper middle fairings and the seat and unplug and plug back in every connector you can find.
Ted
The fast color!!
Green 2005 ZX10R
FBRR
posted November 24, 2007 12:31 PM
There is a post on another forum with some issues with the FOB. Same issue, not a dead FOB, battery on the bike charged and could not get it to recognize the FOB to turn thr key.
Have you done any "wiring " on this bike, such as heated vests or gloves. etc.?
I'm starting to have reservations about the KIPASS/FOB. Let us know if you solve your problem.
I'm planning on buying a C14 this spring.
bigfatboss
posted November 24, 2007 01:24 PM
I have gone through all the connections under the seat figuring a bad or loose connection. I will pull the upper part of the fairing for the rest. I wish I had the second FOB with me. Haven't done any wiring on the bike either. I will check the battery and see if I can get a new one.
rifleman223
posted November 24, 2007 02:57 PM
Here is the text from the manual:
If FOB Key Battery Is Dead
If the FOB key battery is dead, authentication is performed by the transponder and not by the
KIPASS. Authentication requires approximately 1 to 2 seconds.
*It will not detect a battery voltage drop, detect whether the motorcycle is running, or authenticate
the FOB while the key knob is turned OFF.
If the voltage of the FOB key battery has dropped, a warning will appear on the meter as the knob
is turned ON.
bigfatboss
posted December 03, 2007 09:11 AM
Drove all the way to Florida after this incident and only had one more fit..... never had an issue again while I was down there and all the way home. Kind of concerns me. How long do the batteries last in these things?
0.3078191280365 seconds processing time
