Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: Hard bags falling off? NEW TOPIC NEW POLL POST REPLY
Ozzy
need guberment cheese
posted September 09, 2007 03:16 PM
Read over on COG a few of the ZG1400 owners have had one of their saddlebags fall off at hiway speeds.
Make sure you are getting yours fully and corrrectly attached.
"It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses......HIT IT!"
Blues Bros.
posted September 09, 2007 04:51 PM
user error! doh!
rifleman223
posted September 09, 2007 05:48 PM
user error! doh!
+1
Ozzy
posted September 10, 2007 03:55 AM
user error! doh!
Didn' say if it was or wasn't user error, just wanted to let everyone know that it is possible to think the bag is secure and it actually is not.
http://www.concours.org/forum/topic.asp?TOPIC_ID=34891
Blues Bros.
tundra tom
posted September 10, 2007 04:49 AM
From the rear of the C-14 you can easily see if the Red Hook is engaged.....or not.
"When my time has come, I prefer to be in the Saddle rather than the Recliner"
posted September 10, 2007 09:43 AM
I think this topic goes along with other classics like "Don't stick a fork in your eye" & "Don't slam your hand in the car door"
fastestbusaaround
I eat Fish...
posted September 10, 2007 05:51 PM
I heard the same shit when I had my FJR...doorknobs either forget or don't know how to attach the bags properly...
FYYFF!!!
AllStingNoBling
posted September 10, 2007 07:02 PM
Oh, oh, oh!! Don't forget the one about pissing into the flow of a high powered fan!
texcoonazz
posted September 11, 2007 05:08 PM
I am prob opening myself up for a ton of comments but have to add anyway.
I am one of 4 COG members whos side bag came off. And mine was the worst with the bag being totally destroyed by a few Semis. 1 was the result of their own hiccup and the remaining three were apparent lock failures. I cant speak for others but I know without a doubt mine was locked and attached properly. Believe me if I thought for an instant that I did not I would just quietly order a replacement from a dealer with my head held low.
I have sent the locking mech to KAWI but I do not think there is enough left to tell what happened.
I just wanted to share my mishap with others.
Just be aware if you have a new C14.
posted September 12, 2007 07:18 AM
tex... shitty about the semi vs C14 bag! I do have to point out that if you have the key in the wrong position you can push the back latch down and it will almost engage, but not entirely. At this point you might think the bag is locked and secure, but it isn't. You need to have the key in the correct position to close (or I suppose, to be more accurate - push down) the latch mechanism... then turn the key again to physically lock it.
Do you have pictures of the bag?
TedG
posted September 12, 2007 07:22 AM
fish, That is interesting. So far the only reason I have removed the bags is to demonstrate how easy it is to do. But I am going to be dead careful about that key thing from now on.
TedG
posted September 12, 2007 11:36 AM        Edited By: TedG on 12 Sep 2007 12:36
Actually the comments you will get will mostly be helpful, (as long as you don't mind being called a doorknob ..good one FBA LOL) there are a bunch of pretty savvy people over here and on the other bikeland forums that will do everything they can to help.
texcoonazz
posted September 12, 2007 04:47 PM
Thanks for taking it easy on me and I appreciate the feedback.
Fish. Thanks for your input and you are right you can false latch that thing if you are not careful. This did not happen here though. When the bag is false latched or not done properly it sets up a little bit. Not a lot but enough that you can tell it is not flat.
No pictures either. I thought about taken photos prior to handing over to dealer but got caught up in things. The only thing that was left was the handle latch and the latch for the bag itself though. The remainder of the bag was blown into half dollar size pieces.
posted September 12, 2007 09:01 PM
freightliner or peterbilt ? :P
fastestbusaaround
I eat Fish...
posted September 14, 2007 05:40 AM
It was the exact same thing on my FJR...but as long as you know, you can deal with it to make sure it doesn't happen!
FYYFF!!!
wormgear
posted September 28, 2007 06:39 PM        Edited By: wormgear on 28 Sep 2007 22:37
I have a latch failure and the bag has NOT fallen off so this could be a good example of a failure that's not in a million pieces. I just discovered while putting the right bag on that the red latch was not engaged. I took both bags off and compared the two. When I close the handle on the left (good) bag the red latch moves like it should, solidly into place and you can't push it out of place with the handle down. The right bags red latch however moves very weekly towards the latched position and does not get there. With the handle closed (down) the red latch is just flopping around.
It's going to be a week or two until I can get it into the dealer.
Ok I removed the
27016A 27016-0024 LOCK-ASSY,SIDE BAG,RH
And found the two tabs that are part of the red latch sheared off. They were still sitting in the guides but only the grease was holding them in. One pic shows the tab and the other shows it after I extracted it from the grease.
IMO these tabs could be easily sheared off by the force of hitting a pot-hole or attempting to lower (close) the handle with the latch misaligned. I don't recall hitting or doing anything to have caused this.
GodDamnit there's always such a big temptation to be good, to be good! (Tom Waits)
tundra tom
posted September 29, 2007 05:27 AM
Nice ! I wonder if it's worth drilling those out and replacing them with steel roll pins as others have done. Or maybe installing a couple push release pins through the top hooks......or both. Thanks for the heads up WG.
posted September 29, 2007 08:11 AM
interesting!!
wormgear
posted September 29, 2007 11:31 AM
I decided to fix it myself with steel roll pins. Much stronger than original now. Maybe down the road they'll do a recall. Everybody check your red latch on occasion with the bag off the bike and be sure it can't be moved down when the handle is stowed.
TedG
posted September 29, 2007 05:35 PM        Edited By: TedG on 29 Sep 2007 20:43
wormie, great find and repair. You have probably saved a lot of people real trouble. Maybe we should be proactive in this and just do the steel pin thing ourselves before they go bad. It does look like if ever the latch was incorrectly aligned and then forced closed it would shear. Any bets they did it at the dealership?
Ted
2000 Green ZX12 sold
The fast color!!
Green 2005 ZX10R
2009 Concours Black ABS
murlyn
posted September 29, 2007 07:05 PM
wormie, great find and repair. You have probably saved a lot of people real trouble. Maybe we should be proactive in this and just do the steel pin thing ourselves before they go bad. It does look like if ever the latch was incorrectly alighned and then forced closed it would shear. Any bets they did it at the dealership?
I don't know if this applies, but having just returned from the Kawasaki Dealer Meeting in Vegas, I'm somewhat embarrassed to admit that I installed the bags in reverse. I was busy helping with setup and threw the bags on quickly (the bike won't fit in the team transporter with the bags installed.)
I discovered this thankfully because one dealer came and asked us why we had the bags on backwards. To my dismay, he was correct. Unfortunately the mounting mechanism will allow you to latch them in reverse. What I don't know is if they are actually secure that way. Just food for thought. In looking at them, it's pretty easy to get them reversed (if you're not paying close attention.)
wormgear
posted September 29, 2007 09:01 PM
Ted, I thought about moding the other one while I was at it but the way those tabs are tucked in there I could not see how to break or cut them off cleanly. I guess I could have tried misaligning and closing the handle until they snapped, but I couldn't bring myself to do it.
Ozzy
posted September 30, 2007 09:50 AM
user error! doh!
still think so Mr. so quick to judge?
Blues Bros.
posted September 30, 2007 09:57 AM
user error! doh!
yep... I still think it's user error... the only way I can see the latch mechanism being damaged is if you manhandled the bags into place, breaking it yourself... I'm stil trying to wrap my head around the "failure", though I honestly think that 99% of the failures (if there are enough failures to even call them failures) are from people not latching the bags correctly, and as for the internal mechanism "breaking", I'm not convinced that they will break without some sort of "help".
wormgear
posted September 30, 2007 11:13 AM
That's one stubborn smoking baby
0.22851705551147 seconds processing time
