Concourse 14 / GTR1400
BIKELAND > FORUMS > CONCOURS14.com > Thread: C14 Specs... NEW TOPIC NEW POLL POST REPLY
posted June 13, 2007 08:55 PM
C14 Specs...
Engine: Four-stroke, liquid-cooled, DOHC, four valve per cylinder, inline-four with VVT
Displacement: 1,352cc
Bore x stroke: 84.0 x 61.0mm
Maximum torque: 102.5 Lb/Ft @ 6,200 rpm
Compression ratio: 10.7:1
Fuel Injection: Digital Fuel Injection w/ 40mm throttle bodies
Ignition: TCBI with Digital Advance
Transmission: Six speed
Final drive: Tetra-Lever shaft drive
Rake / trail: 26.1 degrees / 4.4 in.
Front tire: 120/70 ZR-17
Rear tire: 190/50 ZR-17
Front suspension / wheel travel: 43mm Inverted, telescopic fork with adjustable rebound damping and spring preload / 4.4 in.
Rear suspension / wheel travel: Tetra-Lever with stepless rebound damping adjustment and remote spring preload adjuster / 5.4 in.
Brakes, front: Dual floating 310mm petal discs with four-piston calipers
Brakes, rear: Single 270mm petal disc
Fuel capacity: 5.8 gal.
Seat height: 32.1 in.
Wheelbase: 59.8 in.
Overall length: 89.4 in.
Overall height fairing lowered / fairing raised: 50.8 in. / 55.3 in.
Overall width at handlebars / at saddlebags: 30.7 in. / 39.4 in.
Dry weight: Concours™ 14 ABS / Concours 14: 615 lb. / 606 lb.
Color: Concours 14 ABS: Neutron Silver
Metallic Diablo Black
Concours 14: Neutron Silver
MSRP Concours™ 14 ABS / Concours 14: TBD / TBD
Warranty: 36 Months
0.41786694526672 seconds processing time
