Honda CBR 1000 RR / CBR1000RR
BIKELAND > FORUMS > CBR1000RR ZONE.com > Thread: electrical problem with 600 F4i NEW TOPIC NEW POLL POST REPLY
blackbullet76
posted July 20, 2010 10:14 AM
My friend bought a stuntbike for $2000. It's an 02 Honda 600 F4i. The wiring has been messed with some, but the problem he's having might be something simple to you guys. Maybe yall can help...
When he got the bike, as soon as you turned the key on, the bike would start without pushing the starter button. He didn't think too much about it and rode it home, but I was worried the starter was still spinning with the engine. He made it home ok. I told him I thought the starter button was hung, but he said he took it apart and it wasn't hanging. Well, this past weekend he was going to ride it to my house so I could work on it, but he only made it about a couple miles and the engine died and won't start back. Nothing works, no headlights or anything. We loaded it in back of a friends truck and brought it here.
So far, I've noticed the battery voltage at the posts read 0 volts when the terminals are connected and it read 8 volts when disconnected. I'm thinking it's got a grounded out hot wire or something, but not sure. I've got the battery out and charged it back up, but I'm not putting it back in until I find the problem. I've got the tank off and working on getting the crash cage off, then the plastic. I'm gonna try to trace and inspect every wire and component that has to do with starting the bike. Any thoughts on what either problem could be would be greatly appreciated! Thanks for reading this long (and probably confusing) post!
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
blackbullet76
posted July 21, 2010 06:15 AM
Ok, just found out that the starter button did work a couple times before it was starting with just the key being on.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
blackbullet76
posted July 21, 2010 09:33 AM
Update, ruled out a hotwire being grounded out. I think the starter relay is messed up. With the key off and touching the battery terminals to the charged battery, it will turn over. With the key on, and touching the terminals to the battery, it will turn over and fire up. All this without using the starter button. Anyone had this problem before?
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
blackbullet76
posted July 25, 2010 10:29 AM
I fixed the bike, had a bad starter relay.
2007 ZX-14 black
PCIII w/track map
BMC race filter
Flies removed
Speedohealer
Vortex rearsets
0.21915698051453 seconds processing time
