BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 and Cycle logic turbo questions NEW TOPIC NEW POLL POST REPLY
dragbikercr
posted November 30, 2013 06:25 AM
I bought a partial Cycle logic turbo kit, looking to see if I need to run a scavenger pump to pull oil back to engine from the turbo. If so what is a good pump to use?
Also looking to run E85, do I need to get bigger injectors for that, if so what size? What about a fuel pump, can I get away with smashing the regulator on my stock pump and get enough pressure or do I need an aftermarket fuel pump? This is going on a 2008 ZX14. Any help or know someone I can talk to would be appreciated.
1badzx12r
posted November 30, 2013 07:41 AM
my advice is this gonna get expensive real quick ..
boostphreak
posted November 30, 2013 03:06 PM
I have done several of these kits. They are fine for low boost street bikes. the weak link on this system seems to be the fuel system. Or should I say lack of a good fuel system. If you want to give me a call I will share what I know and maybe save you some grief or some money or both. 405-863-3162
dragbikercr
posted November 30, 2013 03:41 PM
Thanks Boostphreak, I will give you a call tomorrow or Monday.
Meangreen14
posted November 30, 2013 06:32 PM
Yes do it rite the first time, mine was set up Pritty safe and still hurt the motor get all the info u can get and then some, these guys hear will help you a lot!! Make sure you beef up your fuel system you will need it.
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
1badzx14
08 Turbo zx14!!!
posted December 02, 2013 05:57 AM
I bought a partial kit also ended up upgrading the turbo to a 20g unit,running the muzzy fuel system,used a holley blue fuel pump for my oil scav. setup, lasted me awhile....pulled the motor now putting wossner pistons,head studs,turning up the boost....
dragbikercr
posted December 02, 2013 07:35 AM
I have the upgraded 20g also. What size spring in the wastegate? I have 6 pound spring. What were you running with your setup?
1badzx14
08 Turbo zx14!!!
posted December 03, 2013 11:50 AM
Yea 6 pound and I was making 290 h.p.
Romans
posted December 08, 2013 06:14 PM
Yes, you need a return oil pump. Kavan is what comes with the kit. Buy spares.
Yes you need a fuel pump. Walbro 255 came with kit Also a Rising Rate Fuel Pressure Reg.
E-85 ? 2008 Your injectors are the smallest of all years of the ZX-14 Can they provide 35 % more fuel ??? Trying may be expensive.
Take all the help you can get. Learning curve can be Nasty also very addictive if done so correctly. Have fun, cheers
1badzx14
08 Turbo zx14!!!
posted December 16, 2013 05:53 AM
I also ran a inline check valve on my oil line that way it wouldn't fill my turbo with oil when the bike sits.
0.22622299194336 seconds processing time
